Author Topic: Update on TCs for 85 mm tilt/shift lens.  (Read 2576 times)
Arne Hvaring
« on: March 19, 2018, 19:57:10 »
I have reread Bjørns review of this lens (the first version with the plunger, which is the one I have) and it seemed that all available Teleconverters at the time would fit. I have the 1,7x II and it can't be mounted although there seems to be plenty of clearance. Does anyone know which, if any, of the present TCs that works with the 85 mm T/S ?
Tia.
Re: Update on TCs for 85 mm tilt/shift lens.
« Reply #1 on: March 19, 2018, 21:11:46 »
You need to modify the TC front mount, there is a small tap that needs to be removed
https://nikonrumors.com/2014/10/29/diy-shaving-a-nikon-teleconverter.aspx/
Arne Hvaring
« Reply #2 on: March 19, 2018, 22:53:06 »
Excellent tutorial on removing the annoying tab. Seems like a simple enough procedure. Many thanks Erik for the link!
Cheers
Arne
Macro_Cosmos
    • Flickr
« Reply #3 on: March 20, 2018, 16:20:48 »
Please post your results with the 85pc+tc combo. I have an 85mm pc-e and sometimes use it on a d7100 for 1:1, really decent results I must say. Only thing I dislike about this lens is that incredibly short focus throw, only 1 out of 5 are in focus for me, really hard to use handheld.
Blog: Diatoms Australia
Andor Zyla 5.5 sCMOS | Hamamatsu ORCA-Flash V2 | Nikon Z6 | Olympus Microscope
« Reply #4 on: March 20, 2018, 17:20:33 »
---. I have an 85mm pc-e and sometimes use it on a d7100 for 1:1, really decent results I must say ---
The lens only focuses to 1:2, no matter what camera format it is used on.
« Reply #5 on: March 20, 2018, 17:32:54 »
Meaning the d7100 renders a crop of a 1:2 reproduction of the subject?
« Reply #6 on: March 20, 2018, 17:49:52 »
That is a correct description, yes.
Arne Hvaring
« Reply #7 on: March 21, 2018, 22:57:15 »
The modification went like a breeze. No vignetting even at max tilt/shift. I have only made a quick comparison at near infinity (with all settings zeroed) with the 70-200 zoom set to same FL, about 145 mm. The zoom beats the 85+17TC handily at all stops. Unsurprisingly perhaps. It remains to be seen how the combo performs tilted at shorter distances. Maybe the TC14 would be a better match.
Macro_Cosmos
    • Flickr
« Reply #8 on: March 22, 2018, 16:59:43 »
Thanks for the information!  :)
My 85mm pc-e performs better than my 70-200mm at 85mm, the AF zoom however imo gives a better MF experience... don't know why. For some reason the 3 pc-e lenses have a short focus throw, not sure about the newer 19mm.
Matthew Currie
« Reply #9 on: March 22, 2018, 17:30:59 »
But unless my math is seriously askew (which is quite possible) it's still just a hair shy of 1:1 if you use the camera's crop mode.
It is a hard lens to use hand held.  I don't think it's so much the focus throw as the size and weight.  I've not had that much difficulty just moving a non-focusing lens, but this one is hard to hold steady.
« Reply #10 on: March 22, 2018, 19:42:07 »
Magnification (reproduction ratio) is independent of camera format. Nor is it influenced by cropping.
Matthew Currie
« Reply #11 on: March 22, 2018, 22:51:57 »
Yes, of course, but in terms of "fills the frame as if it were 1:1 in FX" it looks as if it comes pretty close in 1.2 crop mode on top of DX, but still misses by a hair.
« Reply #12 on: March 22, 2018, 23:03:45 »
No, it is not "yes of course": DX vs FX won't give more real magnification. Equalising on angle of view adds no new information and only increases the danger of empty magnification (always a potential issue with smaller formats).
« Reply #13 on: March 23, 2018, 01:19:35 »
The 85 PC lens will focus to 0.5x (1:2) magnification. On FX format that covers 48 x 72mm. On DX format that covers 32 x 48mm.
Adding the TC17E increases magnification to 0.85x (1:1.18). On FX that covers 28 x 42mm. On DX format it covers approx 19 x 28mm.
The different formats only change the framing (cropping), the magnification stays the same.
I suspect the 85PC will have better image quality with TC14E, at the expense of slightly less magnification.
« Reply #14 on: March 23, 2018, 05:02:02 »
What am I missing? Increasing magnification increases coverage no? Why would it get smaller?
