*** Welcome to the new NG Server ***Current status: 106/150 supporters
Doesn't the rear element of the bellows micro 105 hit the front element of Ai(s) micro if the former is mounted onto the latter just with K3? Don't you need, say, a 52mm filter with its glass removed to add some length to K3?
No problem with that combination. There are space enough.For a shorter shade, I use the shade from Voigländer 90mm/3.5. That makes it a lot easier to lighten the subject.
I actually tried just by holding the lenses together by hand, an yes the shade is too long. Will see if something appropriate can be found.
