*** Welcome to the new NG Server ***Current status: 106/150 supporters
I'll suggest that when shooting and you are planning a B&W photograph set the PC in your camera to monochrome with a yellow filter. This in time will change one's mindset. Instead of seeing color as color you'll be thinking about how the colors will translate into shades of gray. When you create your image if it's an NEF you can make full use of the RGB channels to get any filter effect you like, deep red, deep green, deep blue and any combination. You can even change your mind and develop the NEF into a color image. I'm sure there is an equivalent to the Picture Control in any major brand of camera that shoots RAW. Anyway give it a shot. Shoot RAW and monochrome and see if it works the same magic of loading a 35mm camera with Tri-X or Kodachrome. Dave Hartman
