Author Topic: I posted the wrong copy  (Read 6978 times)
basker
« on: December 12, 2017, 22:18:07 »
In posting process I selected the right filename from the wrong folder. What is the procedure, please, for replacing a posted image?
Thanks for your help,
Sam :-[
Sam McMillan
Re: I posted the wrong copy
« Reply #1 on: December 12, 2017, 23:15:18 »
Sam, click "Modify" link right above corner of your post with the wrong image.  You are now in the edit window.  Click "Attachments and other options".  You can remove the posted image in the "Attach:" section by clicking "(clear Attachment)".  Now you can post the correct file again.
You can also add the images through the same procedure.
basker
« Reply #2 on: December 12, 2017, 23:23:47 »
Akira,
That worked perfectly. I did not expect it to be so easy.
Thank you for the prompt and effective help!
Regards,
Sam
Sam McMillan
« Reply #3 on: December 12, 2017, 23:34:12 »
Glad to be of any help, Sam!
« Reply #4 on: December 13, 2017, 15:42:13 »
Akira, thank you on behalf of the Crew.
« Reply #5 on: December 13, 2017, 18:04:36 »
You are welcome, Jakov.  Sam's question was posted while I was awake.  :D
« Reply #6 on: December 14, 2017, 00:40:56 »
That’s the advantage of having kind members around the clock  ;)
