Author Topic: Flash gone weird -  (Read 5558 times)
Flash gone weird -
« on: July 07, 2015, 11:58:19 »
what on earth is going on here?
Flash still works
Re: Flash gone weird -
« Reply #1 on: July 07, 2015, 12:24:27 »
Broken glass (internal) or overheated LCD fluid
« Reply #2 on: July 07, 2015, 13:58:51 »
Yes, needs to go in for service...
« Reply #3 on: July 07, 2015, 14:07:14 »
I assume I should then not use it like this?
« Reply #4 on: July 07, 2015, 14:23:40 »
What happens if you switch it on?
Is there a NPS station near by?
« Reply #5 on: July 07, 2015, 14:30:12 »
It turns on no problem and I can change the MODE
I used it on Saturday for the shoot and had no issues that I am aware of
Keep in mind my knowledge of flash is -Zero.
« Reply #6 on: July 07, 2015, 18:50:24 »
Ok. Then the flash seems ok, only the display is  broken.
Half the people I know with iPhones have broken displays
Thomas Stellwag
« Reply #7 on: July 07, 2015, 19:06:33 »
you need a new display - i think one can see the  v-shaped crack
the blue areas are already without liquid crystal, the brown ones around with changed layer thickness, spacers have moved
the display itself is a passive part, so it should not harm the rest of the flash´s electronic
Thomas Stellwag
« Reply #8 on: July 07, 2015, 20:06:44 »
« Reply #9 on: July 07, 2015, 21:10:47 »
I suppose I will go off to Nikon then :)
I was also given another SB800 by a friend - but its not working - and I think because the batteries leaked
might as well take that in too
PedroS
« Reply #10 on: July 07, 2015, 22:12:54 »
Hi Elsa, it's indeed a broken display.
It can be seen the line where an unwanted force broke it.
Replace the screen. If they ask too much, just bought another one on ebay...
« Reply #11 on: July 08, 2015, 07:38:41 »
so weird since I seriously have no idea how it could have happened - just shows you -
« Reply #12 on: July 16, 2015, 17:11:05 »
Elsa, with your talent ... you don't need no stinking flash.
« Reply #13 on: July 16, 2015, 18:01:33 »
Gary - you are definitely the flavour of my month
incidentally - Nikon says cracked LCD. wont affect the use of the flash - so it will stay as is
« Reply #14 on: July 17, 2015, 06:44:53 »
You can make selections without the LCD being operational?
