Author Topic: UV-Nikkor f4.5 105mm  (Read 3254 times)
« on: July 07, 2015, 11:51:23 »
A few shots I recently made to check a new lens I got...
All shot fully open (f4.5)
Full set is here (only normal visible light images): https://www.flickr.com/photos/kds315/sets/72157655149125569
Admittedly one of the sharpest lenses I own. Surprisingly good bokeh for a mainly scientific lens.
Data is here: http://www.macrolenses.de/ml_detail_sl.php?ObjektiveNr=298
(and btw, the lens is uncoated)
Re: UV-Nikkor f4.5 105mm
« Reply #1 on: July 07, 2015, 13:04:07 »
Congratulations!
Is it New or Used?
Basically it is 'unsuited' for VIS images... without coating...
« Reply #2 on: July 07, 2015, 14:52:18 »
Hi, Klaus, glad to see you here!
« Reply #3 on: July 07, 2015, 15:18:26 »
Congrats on the new lens. I like the colors.
« Reply #4 on: July 07, 2015, 18:29:11 »
Congratulations!
Is it New or Used?
It can't be new Eric, as Nikon stopped making it many years ago ;-)
It just got it back from TLC-CLA, so this were basically test shots...
An intended "work horse", as I don't want to use my other "new" in box, all complete one in the field.
Ditto Akira, we haven't talked for years I guess, I hope all is well!
I found this one in Osaka btw. not too far from you...
Thanks, indeed a great lens, despite being uncoated ;-)
« Reply #5 on: July 08, 2015, 00:08:55 »
Here a test of a metallic precision ruler shot against the light, the worst situation, to see if there is CA.
The color artifacts are grating effects of the metallic surface.
and here a nicer looking test:
both shot fully open (f4.5)
« Reply #6 on: July 08, 2015, 00:20:30 »
Congratulations!
Is it New or Used?
You stated new and it is available new as Tochigi Nikon... so I was just asking:)
http://www.tochigi-nikon.co.jp/en/products/lens/uv.htm
Congratulations, a truly remarkable lens!
« Reply #7 on: July 08, 2015, 00:54:11 »
look sharp to me...
no camera info?
