Author Topic: [Theme] leaves  (Read 116350 times)
Re: [Theme] leaves
« Reply #255 on: May 07, 2019, 01:55:47 »
Shape echo, yin yang
mxbianco
Re: [Theme] leaves
« Reply #256 on: May 17, 2019, 08:20:48 »
Heavy leaves (laser-cut from a 2cm-thick steel sheet)
Ciao from massimo
Re: [Theme] leaves
« Reply #257 on: May 17, 2019, 09:59:06 »
Very nice duality, Paco!
Massimo, this is interesting objet and presentation!
Re: [Theme] leaves
« Reply #258 on: May 17, 2019, 10:00:44 »
mxbianco
Re: [Theme] leaves
« Reply #259 on: May 17, 2019, 10:34:12 »
Those heavy metal sheets are used sometimes in my hometown to surround the trees and protect the roots from car tires and pedestrian boots...
Sometimes a few cigarette butts and napkins get stuck (visible in the photo),  they get cleaned on a regular basis.
Ciao from Massimo
Re: [Theme] leaves
« Reply #260 on: May 17, 2019, 11:45:45 »
Ciao from Massimo
Thank you for the explanation.  Cool idea.  The same protection plates are used here in Tokyo, too, but they are just heavy metal grids.
mxbianco
Re: [Theme] leaves
« Reply #261 on: May 17, 2019, 13:57:57 »
Frosted oak leaves
Ciao from Massimo
Lars Hansen
  • Zealand, Denmark
Re: [Theme] leaves
« Reply #262 on: May 17, 2019, 19:55:05 »
Nice one Akira - that's a lonely looking leaf but a least it looks like its being brushed by sun spots once in a while :-)
Lars Hansen
  • Zealand, Denmark
Re: [Theme] leaves
« Reply #263 on: May 17, 2019, 19:57:51 »
Wet Ivy leaves on a cold, wet and gray May day
Re: [Theme] leaves
« Reply #264 on: May 17, 2019, 21:20:49 »
Thank you, Lars, for your perfect interpretation!  I'm glad that you spotted the sun spots (no pun intended).
Tom Hook
  • Tom
Re: [Theme] leaves
« Reply #265 on: May 23, 2019, 02:11:46 »
Maple Leaves
mxbianco
Re: [Theme] leaves
« Reply #266 on: June 06, 2019, 09:45:11 »
Lotus (?)
Ciao from Massimo
Re: [Theme] leaves
« Reply #267 on: June 07, 2019, 04:41:35 »
Lotus (?)
Lovely green and blue, Massimo.
mxbianco
Re: [Theme] leaves
« Reply #268 on: June 07, 2019, 07:57:04 »
Thanks!
It is natural lighting, the plants were in a small pond under the shade, and there was indirect illumination from a very blue sky. The leaves seemed to be glowing with this light.
Ciao from Massimo
Re: [Theme] leaves
« Reply #269 on: June 10, 2019, 16:26:21 »
I hope it counts
