Author Topic: Laowa 15mm f4,0 wide angle macro lens  (Read 1835 times)
Gigas
« on: October 03, 2017, 17:57:01 »
Hi again! I got this lens today with a Nikon FX mount. The critters I shoot is about 1" long and I had my lens right up to the front glass at the tank. Images are really small so is there a combination of two lenses like the Nikon 105mm and 105 for bellows. Just to get som more WD and a lighter monitor?
Re: Laowa 15mm f4,0 wide angle macro lens
« Reply #1 on: October 03, 2017, 18:13:24 »
The inadequate working distance goes with the territory of a short focal length, so to speak.
You cannot combine this lens in any meaningful way with other lenses, except for adding a TC. Still won't influence the working distance, though.
Gigas
« Reply #2 on: October 03, 2017, 20:48:04 »
Thank you again Bjørn I will use this outdoors for landscape shots.
« Reply #3 on: April 11, 2020, 18:18:56 »
My local photopusher has an offer on this lens, how does it perform?
« Reply #4 on: April 11, 2020, 18:37:23 »
Never used it so cannot say. The Laowa  25/2.8 is a good performance for its price, but of course this is a true 'macro' lens for the 2.5-5X range. Thus not easy to compare against the 15mm.
Bill De Jager
« Reply #5 on: April 12, 2020, 01:47:44 »
Here are a few shots I took a couple of years ago.  These may have compositional and technical shortcomings but I hope they will help.  Photos had highlights and shadows adjusted, with modest enhancement of things like saturation and contrast.  All shots were taken with a Df.
This shows the setup for the dollhouse photo; I ended up posting a shot without flash.
OLYMPUS DIGITAL CAMERA
 by Bill de Jager, on Flickr
Interior of dollhouse, aperture set at f/11.  Despite short focal length and small aperture setting the close working distance limits depth of field.
_DSC8668
Near-far shot with lichen on tree trunk; aperture set at f/11. No flash, and the short working distance reduced light on the center and bottom of the subject.
_DSC8703
Actual pixels showing short depth of field:
_DSC8703_center_crop by Bill de Jager, on Flickr
Shot with flash; aperture set at f/11:
_DSC8708
f/5.6, no flash:
_DSC8722
Cropped, shot at f/11, no flash:
_DSC8742
Cropped, shot at f/8 with flash:
_DSC8793 by Bill de Jager, on Flickr
Conclusion: The lens is fun to play around with despite technical limitations intrinsic to its short focal length.  The short focal length requires getting very close which counteracts the depth-of-field advantage you'd expect from that short focal length.  The short working distance also can interfere with lighting the subject.
I see this lens as more of a lighthearted creative tool rather than a serious macro.  I'll have to try it on the Z6!
« Reply #6 on: April 12, 2020, 08:39:52 »
Thank you for a thorough reply. :)
BW
    • Børge Wahl-Photography
« Reply #7 on: April 12, 2020, 19:51:27 »
I will definitely recommend this lens! I have had lots of fun with it especially during the summers. I have used it a bit lately on my Z6 and it works well. These examples are straight exports from LR, no sharpening applied, so I think it is a very versatile lens. It has some barrel distortion and behave very well stopped down. I have lots of other examples, but these are from recent days.
« Reply #8 on: April 12, 2020, 21:16:12 »
Looks like a fun and sharp lens, thanks for sharing
