Author Topic: Stuck meter coupling lever  (Read 2406 times)
Frode
« on: September 16, 2017, 00:15:00 »
The meter coupling lever is stuck on my D300s.
I don't use any manual lenses on this camera (D4s does that job), so I'm wondering if this is something I have to repair due to other functions?
If so; any idea how much such a "fix" will cost?
Don't know how this happened, suggestions on common causes?
Re: Stuck meter coupling lever
« Reply #1 on: September 16, 2017, 00:19:51 »
Very common, not expensive
Frode
« Reply #2 on: September 16, 2017, 09:02:55 »
Thank you, Erik  :)
Regarding functions; only relevant when using manual lenses?
longzoom
« Reply #3 on: September 16, 2017, 17:20:46 »
Do not set any manual lens on the camera, as well as some old-fashioned AF ones, were part of the info goes thru this lever. In this case, by turning aperture ring, this stuck long inner spring could be broke apart, and make a real mess inside. If the lever stuck in any between position, it may, in some cases, with some, mostly third-party lenses,  affect the metering. Bring it to service ASAP, ASAP I do mean!  Good luck!  LZ
Frode
« Reply #4 on: September 16, 2017, 20:16:25 »
Thank you :-)
I'll send it in, won't take any chances.
