Author Topic: AF-Nikkor 28-105 mm f/3.5-4.5 IF -- Infrared performance ??  (Read 1058 times)
typestar
« on: September 13, 2017, 21:46:58 »
Hi all,
Hi Bjoern
as it is availble really cheap now -- I am  interested in the AF-Nikkor 28-105 mm f/3.5-4.5 IF
for use on an infrared converted Camera (either Nikon D5300 -- [built-in GPS and would fit the plastic look of the lens]
or a Sony Alpha 6000 (APS-C)   or a full frame Alpha 7 M2 ---
I read the reviews of some "old" Nikkors years ago --- (http://www.naturfotograf.com/lens_zoom_02.html)
and  http://nikongear.net/revival/index.php?topic=2733.0  (Bjoerns info about his walk-around IR-lens)
I consider Bjoerns recommendation of the  AF-S  16-85 ED DX lens  for IR ...http://www.naturfotograf.com/lens_zoom_01.html#AFS16-85EDGVR
as this would fit better the APS-C cams...
Can someone report on the power of the AF-Nikkor 28-105 mm f/3.5-4.5 IF lens on IR converted cameras (internal 720 nm conversion)
Thankyou for your thoughts and guidance!
Christian
typestar
Re: AF-Nikkor 28-105 mm f/3.5-4.5 IF -- Infrared performance ??
« Reply #2 on: September 14, 2017, 13:33:06 »
thankyou Eric,
I just check this...
best wishes!
