Author Topic: preferences of the 1.8 AFS-Nikkors  (Read 6523 times)
Per Inge Oestmoen
  • Long Live NikonGear
Re: preferences of the 1.8 AFS-Nikkors
« Reply #30 on: June 11, 2017, 15:29:23 »
I'm happy with my AF-S 24/1.8. Sharp across.
Yes, but could it have been even better if you had used an aperture of, say, F/8 or F/11 instead of F/13? Just a thought.
"Noise reduction is just another word for image destruction"
Per Inge Oestmoen
« Reply #31 on: June 11, 2017, 15:42:33 »
The aperture setting also has an important influence for the appearance of the sun rays and size of the solar disk. Thus one has to find a balance between need for stopping down and keeping the required image quality. Fixed recommendations for aperture is tricky at best.
« Reply #32 on: June 11, 2017, 15:59:01 »
I cannot fault my 20mm 1.8G either.
Is the purple and green fringing shown in the branches characteristic of the 20mm f/1.8 lens? Seems a bit strong.
« Reply #33 on: June 11, 2017, 16:18:20 »
Most lenses will have troubles with excessive contrast like that of the derelict house Per Inge posted. Some of the fringing might be removed in the RAW converter though (if the software supports such corrections).
Per Inge Oestmoen
« Reply #34 on: June 11, 2017, 18:54:40 »
Yes, it is typical.
It is also typical of every lens I have ever come across against similar subjects.
Per Inge Oestmoen
Per Inge Oestmoen
« Reply #35 on: June 11, 2017, 18:56:54 »
I guess the best recommendation is to state that the best aperture - like many other parameters - depends on exactly what one wants to convey and how.
Per Inge Oestmoen
