Author Topic: IR Mania with old Nikkors  (Read 26075 times)
Bill De Jager
Re: IR Mania with old Nikkors
« Reply #15 on: June 04, 2017, 06:41:27 »
Here was my lens of choice today, on a Sony A6000 converted to broadband:
S 105 2.5 PC by Bill de Jager, on Flickr
It's the S-mount 10.5cm f/2.5 P.C.  This is a Sonnar lens that was reissued in F mount later, before being superceded by the double Gauss 105mm f/2.5 lens that's more familiar to Nikon users. According to Roland's site, the S-mount version started production in 1953, the F-mount version started in 1959, and the optics changed in 1971.
I used a B + W 093 filter to get a fairly monochrome IR look which I then desaturated.
IR Dead Pine by Bill de Jager, on Flickr
IR Sycamore v2 by Bill de Jager, on Flickr
The second photo is not a negative despite its appearance.  I did darken the sky to black to increase visual contrast.
IT Thistles by Bill de Jager, on Flickr
IR Blue Gum by Bill de Jager, on Flickr
« Reply #16 on: June 04, 2017, 09:32:45 »
Nice old-timer IR, Bill. I haven't used the 10.5 cm f/2.5 S for IR yet, only the slightly modified 105/2.5 F "Sonnar" version. However, all of the 105/2.5 versions apparently are performing well in IR.
« Reply #17 on: June 04, 2017, 10:46:22 »
Examples of 105 mm f/2.5 Nikkor (AI) for IR. The Dutch mills with D5300, the soaring seagull with D200.
« Reply #18 on: June 04, 2017, 12:36:40 »
Another favourite with IR is the 16/2.8 Fisheye-Nikkor. The f/3.5 version is a tad sharper, but doesn't allow as close focus (Erik modified my 16/2.8 to give extra close near limit).
On the DX cameras, the fisheye geometry becomes less overwhelming as well.
« Reply #19 on: June 04, 2017, 13:22:59 »
The 16/2.8 Fisheye-Nikkor is also perfect if one wants to shoot flying bananas in IR.
« Reply #20 on: June 04, 2017, 17:13:39 »
Your IR photos are always huge treat, Bjørn. What nm filter was used in this modified D200?
« Reply #21 on: June 04, 2017, 17:27:07 »
720 nm class filters on all of them.
Bill De Jager
« Reply #22 on: June 04, 2017, 18:26:19 »
Thanks, Bjørn.  I really enjoyed working with this lens.  One thing to watch out for is that changing the aperture tends to inadvertently change the focus.  Also, the lens is vulnerable to flare; I should have looked for a hood to fit onto the 52mm filter threads.  The biggest problem I ran into is the usual one with using a manual-focus lens handheld on a mirrorless camera - focus peaking only provides approximate focus accuracy. The lens is plenty sharp when it's actually in focus.
« Reply #23 on: June 04, 2017, 23:57:50 »
Nikon D200 RG665,Nikkor 16mm f/3.5 AI Fisheye
1/640s f/5.6 at 16.0mm iso160
« Reply #24 on: June 04, 2017, 23:59:59 »
Nikon D200 UV-VIS-IR and UG-1,Nikkor 20mm f/3.5 Nikkor-UD Auto
1/40s f/5.6 at 20.0mm iso16
Nikon D200 UV-VIS-IR RG1000,Nikkor 20mm f/3.5 Nikkor-UD Auto
1/40s f/5.6 at 20.0mm iso160
« Reply #25 on: June 05, 2017, 00:02:19 »
IR-84 TAC Filter
Nikon D300S UV-VIS-IR,Nikkor-QD.C 15mm f/5.6
1/80s f/8.0 at 15.0mm iso200
Bill De Jager
« Reply #26 on: June 05, 2017, 06:08:48 »
Next lens: Nikon PC-Nikkor 35mm f/3.5, old version with chrome knob, on a Metabones Speed Booster Ultra (because I couldn't find my F- to E-mount adapter) and Sony A6000.  The lens was not shifted for any photos.
Nikon PC-Nikkor 35mm f/3.5 by Bill de Jager, on Flickr
I also couldn't find my 720nm IR filter, so here are more with the B + W 093:
Sunstar in Park by Bill de Jager, on Flickr
IR Tree Trunks by Bill de Jager, on Flickr
« Reply #27 on: June 05, 2017, 07:10:51 »
Enjoying the thread very much!
« Reply #28 on: June 05, 2017, 07:43:26 »
not without colours
D5300 720nm, Ud-nikkor 20mm f/3.5
« Reply #29 on: June 08, 2017, 22:20:30 »
I took my 28mm 2.8 (min focus 0.3 m) for a spin today with the ir D80.  Metering was a wild guess. Most images are around f/8 and 1/320 s at base iso. Here you have some distant, medium and close range. The images came out full of detail.
