Author Topic: Wide Angle For Landscapes  (Read 4953 times)
Sherman71
« on: May 12, 2017, 18:18:04 »
I own a D300 and was thinking about a 20 or 24mm AIS Prime for landscapes. How do these compare to the 35mm 1.8 g (which I own).
Re: Wide Angle For Landscapes
« Reply #1 on: May 12, 2017, 18:51:26 »
If you want a modern lens with all that entails, the 24/1.8 AFS is an obvious choice. Going the AI/AIS route, the 20/3.5 UD, 20/4, or a good copy of 24/2 can be evaluated. For the 24/2.8 Nikkors, the early 'K' is also possible if it is AI-modified.
« Reply #2 on: May 12, 2017, 22:47:32 »
Hi, Sherman71, welcome to NG!
I used AF-S24/1.8G on D750, and haven't found anything to complain about maybe except for the size (but not the weight).
The point would be if the angle of view is wide enough for your need.  If you want to go wider, AF-S 20/1.8G would also be a potent candidate.
« Reply #3 on: May 13, 2017, 00:06:29 »
Can I suggest you look at the 18mm as well? I prefer that angle to 20mm though it is subtle. Should work well with your 35mm
« Reply #4 on: May 13, 2017, 00:28:27 »
Landscapes and ultra wide lenses don't match well in my opinion. I do know this goes against the usual recommendations, but so be it. Take the opinion for what it is worth.
The various 18 mm Nikkors are fairly good, but most of them are old designs if we're talking primes. The 14-24/2.8 probably will outperform these in most situations. However that will not entail it is  the "better" lens as a lot of other considerations come into play.
longzoom
« Reply #5 on: May 13, 2017, 01:04:03 »
2017-05-12 001-1 by 2017-05-12 019-1 by 2017-05-12 022-1 by longzoom2017-05-12 022-1-2 by 2017-05-12 023-1 by longzoom, on Flickrlongzoom[/url[url=https://flic.kr/p/UxJnDg]2017-01-15 002-1-2 by longzoom, on Flickr0_b.jpg[/img][/url]2017-05-12 023-1-2 by longzoom[/url[url=https://flic.kr/p/Q1BfUt]2017-01-15 002-1-3 by 2017-01-15 002-1 by longzoom, on Flickrlongzoom, on Flickr], on Flickr], on Flickr, on Flickrs/longzoom/]longzoom[/url], on Flickrtos/longzoom/]longzoom[/url], on Flickr.   There are better wide lenses, not much, thou, but for quality/price consideration the old AF or AF-D Nikkor 20/2.8  is spectacular. If you got the good copy, of course. 3 last images with crops. Those are not pretending on any Art quality, for sure, just to show the technical abilities of that old loyal dog! Good luck!   LZ         (Two missing images are in the post next to this. Sorry).
longzoom
« Reply #6 on: May 13, 2017, 01:07:58 »
2017-01-15 002-1-2 by 2017-05-12 023-1-2 by longzoom, on Flickrlongzoom/]longzoom[/url], on Flickr.  Two images are missing in the post above - main and crop. Sorry for this!  LZ
Mongo
« Reply #7 on: May 13, 2017, 01:44:32 »
If you go the modern approach, then, the 20mm f1.8 and 24mm f1.8 are excellent choices.
If you go the AI or AIs route, then, most of the 20mm and 24mm are quite good. Some can be larger and heavier. Mongo still uses a 20mm f3.5 as the smallest and gives very reasonable results (especially at f8 and f11). Had the 24mm f2 but found it was not great wide open but would perform very well stopped down. In the case of the 24mm f2, if you are not using it for journalism and having to stop down to use it for landscapes (which are generally stationary), then, there is little purpose in f2. Would suggest you try 24mm f2.8 instead.
CS
« Reply #8 on: May 13, 2017, 07:12:15 »
Define what you see as "wide" on your D300 body.
Since your D300 has the 1.5 crop factor, none of the lenses mentioned so far are really wide mounted on that body. That is not saying that the mentioned lenses are bad. Your own 35mm is hardly wide on the D300 with it's 52mm FOV. Nikon has not really put any effort into wide primes for DX, for wide they only offer a couple of DX zooms, the 12-24 and the 10-24. Yes there is the 10mm fisheye.
I have the 12-24, and the 12m (18mm FOV) wide end is not where it performs best. If you take it out to 24mm, it's a pretty good lens, but that's a 36mm FOV on a DX body, a long way from the wide FOV lenses used by FX bodies.
Carl
« Reply #9 on: May 13, 2017, 07:15:22 »
Any particular reason you want AIS prim lenses? For landscapes on a DX body, the AFS 18-35 or AFS DX 12-24 are likely to be more versatile.
Mongo
« Reply #10 on: May 13, 2017, 08:17:51 »
yes, the others are correct. Mongo also momentarily forgot that the D300 is a DX format. Surely you might want a lens that would effectively yield a 20mm to 28mm final image......???
« Reply #11 on: May 13, 2017, 08:49:19 »
Instead of buying a new lens, how about buying a full frame camera?
« Reply #12 on: May 13, 2017, 10:31:21 »
Take a look at the very versatile 1.8/20G which was introduced together with the D750 a while ago. Smashing lens and a bargain for 800€. Also ultra-wide with a FX body
« Reply #13 on: May 14, 2017, 05:03:39 »
Excellent suggestion! I own a D300s that only gets a little use. My primary camera is now a D800. The D800 gave me back my 105/2.5 and wide angles.
« Reply #14 on: May 14, 2017, 08:44:57 »
Landscapes and ultra wide lenses don't match well in my opinion. I do know this goes against the usual recommendations, but so be it. Take the opinion for what it is worth​.
Years back, maybe 1973, I took a photograph of three minor peaks on a backpack trip in the Eastern Sierra Nevada. I was drawn to the colors and shapes. I used a 105/2.5 as that framed the peaks nicely but as I did I wondered if I should use a 105mm as everyone knows you use a wide angle for landscape. I'm glad I did as I liked the photo. It's funny I remember my thinking as took the photograph.
Sherman71,
Today I figure you use any lens that gets the photograph you want. With an ultra wide angle you'll get a lot of foreground and the middle and background will be quite diminished. A super telephoto will look over the foreground and middle ground. Both extremes may be difficult to use.
What about an AF-S 16-85/3.5-5.6G ED VR DX? 16mm is quite wide, not quite super wide; while 85mm get you a medium telephoto. I don't own the lens but I've use my friend's and I quite like the lens. I find it a good walk around lens.
I still think an FX camera is a good idea.
