Author Topic: Deep in Devout Discussion  (Read 1046 times)
Mongo
« on: April 15, 2017, 09:33:06 »
A candid on the beach walk. It is unfortunate that the hight of the grasses intruded a little too much into the image.
D800E and 200-500mm
Re: Deep in Devout Discussion
« Reply #1 on: April 15, 2017, 09:38:11 »
Right. Maybe slightly desaturate the greens ?
Mongo
« Reply #2 on: April 15, 2017, 09:49:53 »
thanks for confirming what Mongo suspected Airy. Because the main subjects are largely black, the choice is to turn the image into a mono or take the colour out of the grass and hope it is less distracting and merges better with the predominant colours. Here are both - any suggestions ??
« Reply #3 on: April 15, 2017, 10:01:44 »
Both versions work. On the B&W one, I'd suggest you further tweak the color channels so that the faces stand out even more. And the foaming waves will probably require masking, since they are white: the ones on the top right are too bright, and should get to the level of the middles ones, IMHO.
Mongo
« Reply #4 on: April 15, 2017, 10:04:41 »
big thanks Airy - really appreciate the considered advice. Mongo also suspected the male's face was a little "flat" and waves behind a little bright
« Reply #5 on: April 15, 2017, 10:07:51 »
The subtle contrast between beard and background wave is quite OK though. Neither blending nor standing out.
