Author Topic: Dismantling the Nikkor-S.C 55/1.2!!!  (Read 1171 times)
« on: March 18, 2017, 03:20:58 »
http://richardhaw.com/2017/03/15/repair-nikkor-s-c-55mm-f1-2/
OK, back to F-mount lenses  ::)
currently having so much fun with S-mount lenses and Zeiss and Leica clones from Nikon :o :o :o
the rangefinders are way more fun to work with
Re: Dismantling the Nikkor-S.C 55/1.2!!!
« Reply #1 on: March 28, 2017, 02:58:07 »
This lens is exactly the same as its successor optically ...
The S.C is optically similar to the New Nikkor (K) version, but the design has been tweaked with different lens curvature, spacing and possibly glass material. The change may be to improve close range performance since the New Nikkor focuses closer (0.5m) than its predecessors (0.6m)
This change follows an earlier improvement to the optics, probably occurring when the early 9xxxxx serial numbers switched to the new series starting at 184711. Overall the lenses are similar but again, the lens curvature and spacing was changed.
« Reply #2 on: March 28, 2017, 03:29:42 »
Thanks for pointing that out :o :o :o
I changed it during my coffee break!!! added your tidbits
