Author Topic: Question on a 15mm f/3.5 ai-s  (Read 4487 times)
« on: March 17, 2017, 12:44:18 »
I have a 15mm f/3.5 ais here at my disposition with a rear bajonet filter type A2 attached, when i take the filter out it doesnt focus beyond less than a meter.
Strange, in my opinion the filter should not interfere with the focus just give it a warmer tone?
Re: Question on a 15mm f/3.5 ai-s
« Reply #1 on: March 17, 2017, 12:57:38 »
That is not correct. As the filter is part of the optical system (by virtue of being in the light pathway) it most definitively will influence focus. Expect a focus shift approx. 1/3 of the filter thickness. Perhaps not much in absolute figure, but for a short focal lens such as the 15 mm, that will throw infinity focus well and truly off, as you already discovered.
chris dees
  • Amsterdam
« Reply #2 on: March 17, 2017, 12:58:11 »
Should't you replace it with a clear filter? As with the 16/2.8 AI-S fisheye.
Chris Dees
« Reply #3 on: March 17, 2017, 12:59:42 »
There is an L1Bc filter as part of the standard kit for the 15/3.5. Use that filter or do an extra click-white if the A2 is deployed.
The 15/3.5 uses the identical filter kit to the 16/2.8 Fisheye.
« Reply #4 on: March 17, 2017, 13:05:02 »
Thanks for the clarification. :)
« Reply #5 on: March 17, 2017, 17:58:31 »
Nikon made (makes?) both an L1Bc (very pale magenta "skylight") and an L37c (close to colorless) for that 39 bayonet mount.
« Reply #6 on: March 17, 2017, 18:07:36 »
True, but I think only L1BC was delivered with my 15/16 mm lenses.
L37C is practically worthless in terms of any UV attenuation, but it does serve a purpose in ascertaining the correct focus.
« Reply #7 on: March 17, 2017, 18:17:35 »
Searching on the internet the availbility of  these filter sets brought up nope, may have to get a nikkor 16mm fisheye for that ;D; without the corrective glass element  the minimum focal distance shortens.
« Reply #8 on: March 17, 2017, 21:30:47 »
Why not continue to use the A2? in the digital era, correcting w/b is a breeze.
« Reply #9 on: March 17, 2017, 21:44:19 »
By the way, the filter set is delivered in a leather pouch labelled CA-2.
« Reply #10 on: March 17, 2017, 21:50:16 »
True, driven by curiosity i suppose.
« Reply #11 on: March 17, 2017, 21:50:33 »
The L1Bc was part of the standard filter set and installed on my 16/2.8 AIS Fisheye.as delivered. If memory serves me the L1Bc is approximately a CC025M filter.
The L37c was an available extra cost option. It doesn't add a yellow tint as it's very close to colorless. The L37c may be hard to find used. I may have had to special order mine.
Peter Forsell
  • A Cunning Linguist
« Reply #12 on: March 17, 2017, 22:06:18 »
Yes! That "CA-2" was the magic word. I got curious too and tried to find the filter but couldn't. But with "CA-2" as the search phrase there's plenty of them. This is just a random pick (not in Europe):
http://www.ebay.com/itm/Genuine-Nikon-39mm-Bayonet-Filter-Set-B2-O56-A2-for-13mm-15mm-f-3-5-16mm-f-2-8/322446736554?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3De0aa9e58155a424bb56a58fe91d61978%26pid%3D100011%26rk%3D1%26rkt%3D1%26sd%3D321745333040
« Reply #13 on: March 17, 2017, 22:32:30 »
Do note the complete kit should comprise 4 filters.
« Reply #14 on: March 17, 2017, 23:38:37 »
Those rear filters are still listed in the online catalog of Nikon.  L37C is readily available at some large retailers.
