Author Topic: NX-D load to MAC problem  (Read 3737 times)
Pistnbroke
« on: January 21, 2017, 15:49:54 »
Loaded NX d to my PC  and it worked but kept crashing /Freeze.   So loaded to the I Mac and it says does not have the correct application to run it ....Give me a hint please !!
Re: NX-D load to MAC problem
« Reply #1 on: January 21, 2017, 15:54:16 »
Don't know 'bout the PC, but i trust you've downloaded the mac version before trying to "load" it there. PC apps don't run on macs. The mac version can be downloaded from the nikon website.
Pistnbroke
« Reply #2 on: January 21, 2017, 17:17:37 »
I have loaded the mac version onto the mac ..but says don't have right application to run.
« Reply #3 on: January 21, 2017, 19:29:33 »
This is the application you should download http://downloadcenter.nikonimglib.com/en/download/sw/81.html
And if you want us to be of any help, you should enlight us on hardware, OS version, screen captures and the like.
« Reply #4 on: January 21, 2017, 20:26:33 »
I've removed NX-D from my computer, but i remember that you need to run a setup/install program. It doesn't run straight away.
Did you do that (the downloaded DMG is the actual installer, not NX-D itself)?
Pistnbroke
« Reply #5 on: January 22, 2017, 15:19:24 »
Don't leave jobs to the wife ...spotted it was exe not dng ...not her fault the Nikon logic selecting PC or mac is a bit irish..opposite to what you would think ....thanks for the help
« Reply #6 on: January 22, 2017, 15:23:39 »
Some OS think it is better to "hide" the file extension. Thus the actual file might different from what is expected and none the wiser, until one is attempted to execute it.
« Reply #7 on: January 23, 2017, 02:27:20 »
there was an advisory lately about using nikon software with the latest macOS :o :o :o
your files might get corrupted ::)
« Reply #9 on: January 23, 2017, 04:38:08 »
OS X 10.11.6 El Capitan allows displaying extension and hidden, system files. None of these are displayed by default. I set my Windows 7 box and iMAC to display all.
Pistnbroke
« Reply #10 on: January 24, 2017, 09:20:51 »
I took a pic in RAW and Jpeg so identical ..I just wanted to work on the raw and then save as a jpeg to see if there is any difference.
I usually shoot jpeg  large basic...Suspect it wont be worth the effort ...
Lorne
  • it started with a Nikkormat
« Reply #11 on: January 25, 2017, 04:14:53 »
To the OP:
Check to make sure that you have the most current version: Capture NX-D1.4.3
Richard: the trouble was with the Transfer 2 element of ViewNX-I, this issue has been resolved in the current version: ViewNX-i 1.2.4. Btw, Transfer 2 is not integral to C NX-D but was with C NX2.
To clarify, Nikon's download site usually directs Macs and PCs to the appropriate download. I assume this is done based on a handshake with the browser, much like websites tailor the content depending on whether you are on a mobile or a laptop.
« Reply #12 on: January 25, 2017, 09:14:56 »
It's up to you to evaluate. JPEG "onboard processors" are now very good (I think on my D5). Don't forget that JPEG is only 8 bit (256 nuances). This might be enough depending the purpose.
« Reply #13 on: February 06, 2017, 08:13:13 »
If you open the NEF in CaptureNX-D and make no changes then convert to a JPG with the same level of compression the outcome should be quite identical.
To see a difference you would use the many controls available in CaptureNX-D or another program to improve the photo. Then you would convert the developed and adjusted NEF to JPG and the results might be fairly similar to very different. When you work with the NEF there is a lot of flexibility and the choice is yours.
« Reply #14 on: February 06, 2017, 08:21:37 »
If VNX2 or CNX-D crashes in the same folder while creating thumbnails a file probably has been straightened and not cropped. I verified this very carefully a few times. I type this over and over. I wonder if anyone notices? I wonder if anyone has checked and confirmed this? Maybe someone has put a spell on me?
