Author Topic: [long time series] A bridge under construction.  (Read 4661 times)
« on: November 09, 2016, 13:28:04 »
A bridge under construction. Series over the time the reconstruction needs ... two or three years.
Background information: Bonn was once an undived city. On 15. February 1844 the first part of the division had taken place when the train route from Cologne opened.  It was finalized on 18. October 1855, when the southern extension of that train track was taken under steam. All the roads and alleys were cut in half, all connections lost.
Therefore tunnels and bridges were built in the aftermath of the devision to reconnect the now divided parts of Bonn.
One of these bridges is called "Victoriabrücke" and was originally errectet in 1905, destroyed in WW2, replaced on 22. December 1949 and extended in 1963, the construction we see today.
My first set of pictures shows how badly this bridge is damaged by rust and the load of traffic that was counted in 2006 at 34.000 vehicles per day. The bridge is closed for heavy lories above 16 tons since 2010, because it is not considered stable enogh anymore.
Currently half the bridge is closed for traffic, torn down and destined to be replaced.
Re: [long time series] A bridge under construction.
« Reply #1 on: March 15, 2019, 18:16:46 »
state of today, one brige head was torn down and rebuilt, the other is just being torn down, reinforced and rebuilt.
« Reply #2 on: March 15, 2019, 18:18:37 »
and more
« Reply #3 on: March 15, 2019, 18:20:18 »
and even more
« Reply #4 on: March 15, 2019, 19:53:53 »
interesting
good thing maintenance is done, we had a similar renewal a couple of years ago
traffic gets more complicated as the construction is ongoing, but has to be done
« Reply #5 on: March 16, 2019, 12:57:58 »
Your hi-res rig does justice to the motifs.  Really enjoyable series.
« Reply #6 on: March 16, 2019, 12:59:00 »
Frank, I much prefer the pics with DOF taken with oly and Nikon 105mm stopped down (f/5, f/5.6) than the ones at full aperture (f/1.4), cause they suit better for documentation. (except the pics showing close action, though).
Very useful historical references, making your reportage interesting.
Huge works, by the way.
« Reply #7 on: March 16, 2019, 13:08:05 »
Francis: I prefer f/4 or f/5.6 for documentation as you do too, yet, some of the scenes are more emotional graphical colorscapes, not documentation, e.g. the very first shot with focus on the blue jacket biker
« Reply #8 on: March 16, 2019, 13:12:24 »
thank you, Akira. I love the concrete surfaces worn and new. they feel almost tactile in my eyes.
« Reply #9 on: March 16, 2019, 13:13:57 »
interesting
they have a tendency to let public goods rot until you cannot save them anymore...
« Reply #10 on: March 28, 2019, 11:20:51 »
OK. Next stage, yesterday: they broke down most of the old bridge head and started rebuilding it. The bridge head on the opposite side and the Walls that will support the new bridege are already new.
« Reply #11 on: March 28, 2019, 11:23:39 »
OK. Next stage, yesterday: they broke down most of the old bridge head and started rebuilding it. The bridge head on the opposite side and the Walls that will support the new bridege are already new. heavy anchors hold the part in place which is still in use. before they cut away a lot of the bridge they drilled deep and put rebar boxes inside the drill holes later flooded with concrete to make foundation columns...
« Reply #12 on: March 28, 2019, 11:25:51 »
Here you can see some of the stages of bridge history: blocks of stone, triple thick brick walls, reinforced concrete structures ...
Sorry about the last one. it is clearly misfocussed. I will try to get a clear shot later this week.
« Reply #13 on: March 28, 2019, 20:59:50 »
Elaborate brick work.  Should be tough to break down.
« Reply #14 on: March 31, 2019, 18:47:54 »
Here are the promised "corrections":
