Author Topic: Nikon Extension Tube with Full AFS Contacts  (Read 28257 times)
Re: Nikon Extension Tube with Full AFS Contacts
« Reply #30 on: December 17, 2016, 20:13:10 »
Full AF and Aperture control?
The picture Akira just posted does not show the contact block.
Frank, you should see the teeny-weeny bit of the contact block on the camera mount side.  :)
« Reply #31 on: December 17, 2016, 23:24:09 »
Akira. I found a listing at an online photo shop selling tge Kenko 1.4 for Nikon with the contact block visible.
« Reply #32 on: December 18, 2016, 13:00:38 »
With the same idea in mind, I bought a AF Vivitar 1.4x and a AF Tamron 2x for cheap some time ago. They both have a 7 contacts block.
« Reply #33 on: December 18, 2016, 13:43:50 »
do they support Nikkor-E lenses?
« Reply #34 on: December 18, 2016, 14:25:34 »
About the ask the same: for such items to be eligible as candidates for "pass-through" extension, they need to preserve functionality of 'E' lenses. Plus the inner tube has to be wide enough so as not to cause vignetting.
Being robust and securing a sturdy connection to the camera is a given requirement as well.
« Reply #35 on: December 18, 2016, 14:44:06 »
The contact blocks of Bruno's TCs have seven contacts.  The new TCs by Kenko-Tokina that are compatible with G and E Nikkors (called TELEPLUS HD) have eight contatcts:
http://dc.watch.impress.co.jp/docs/news/1032981.html
(Frank, sorry, the image of the latest TCs can be found in the webpage linked above.  The previous link is for an older TC.)
However, the 300/4.0 FP has ten contacts.   :o :o :o
« Reply #36 on: December 18, 2016, 15:11:47 »
.... However, the 300/4.0 FP has ten contacts.  ...
So has the TC-14E.2 that Erik used as material for the pass-through extension.
chris dees
  • Amsterdam
« Reply #37 on: December 18, 2016, 16:33:11 »
Sorry for the somewhat late reply.
The Kenko I have is the Kenko Teleplus PRO 300 DGX 1.4x AF Teleconverter. The image is not 100% the same one as I have, but very similar. It has 8 pins on the other side.
IMHO it's not usable. AF is ok (on a D500) but IQ is lousy, but I tried only for a few images.
First one is at about 5m, the second about 25m. Both very soft and hazy (it's not the lens nor the camera ;D)
I did not tried the converter with other lenses yet.
Bot images are cropped to about 1800px
@Bjørn - I take it with me the next time we meet
Chris Dees
« Reply #38 on: December 18, 2016, 17:22:03 »
'Not usable' is apparently an understatement ....
Besides, the internal opening is small and will cause vignetting for lenses with a large exit pupil.
« Reply #39 on: December 18, 2016, 18:20:31 »
I don't have an E lens, so can't test but AF and metering do work fine with a 80-400 AF-S on a D750. The inner hole is 34mm on both the Vivitar and Tamron, without Dremeling. Increasing it would require touching the contact block.
Kim Pilegaard
  • "Nikea"
« Reply #40 on: December 18, 2016, 19:22:51 »
Maybe I missed something, but what is wrong with the Kenko Auto Extension tubes - maybe too narrow?
Kim
PedroS
« Reply #41 on: December 18, 2016, 19:34:22 »
Don't think so, but the quality is marginal and there's movement when coupled with the lens.
Body is soft plastic and locking system is, again, marginal in quality.
I have used two of them to make a PB-5 all electronic connected, thought.
« Reply #42 on: December 18, 2016, 19:37:18 »
Hope that problem is solved on the new models.
« Reply #43 on: December 22, 2016, 12:07:38 »
Can you post a DIY guide on this operation? I am tempted to try my luck disassembling the 14E I got yesterday and making the extension tube myself
« Reply #44 on: December 22, 2016, 12:39:18 »
That might turn out to be an expensive learning session.
