Author Topic: Lock that "L"!  (Read 11533 times)
Lock that "L"!
« on: October 02, 2016, 03:12:34 »
My deteriorated eyesight doesn't allow proper manual focus on the matte using a DSLR, so I always depend on AF or the focus aid in the optical viewfinder.  And thus I always use the 4-way switch to move the single AF point around.
Sometimes I feel pressed, because I cannot move the AF point, and the 4-way switch doesn't respond.  Then I find that the "L" lever around the switch is inadvertently set to "L" position, which happens every one in a while.
Since I've never been in need of locking the 4-way switch on a digital camera of any brand because of the purpose described above, I decided to lock this irritating "L" switch on my D750 permanently yet in an invertible way, unlike our beloved fierce bear who would use epoxy.  :D
It was easy to find the way to lock the switch thanks to its deeply scooped area to the left of the tab unlike other Nikon models.  I cut a small piece of plastic (red with leather-like emboss) to fit into the scooped area, and fix it to the place using a piece of double-sided adhesive.
I'm very happy with the result.  Now the "L" switch is worry-free!  Sorry for the terrible image quality of the attached image which was taken by my now-very-dated cellphone (this is the only camera that can take the picture "of" my D750!) and heavily cropped.
Hope this post of mine would make any sense....
Re: Lock that "L"!
« Reply #1 on: October 02, 2016, 03:32:22 »
A roll of double sided sticky tape is one of those very useful things like duct tape that should always be a part of ones tool kit - even when travelling.
Nice application for double side tape BTW - I think that we have all run foul of the L lock switch at some time or other - I certainly know that I have.
Matthew Currie
Re: Lock that "L"!
« Reply #2 on: October 02, 2016, 03:51:41 »
Funny thing, one of the worst features I find on the D3200 is that the control does not lock!  To each his own, I guess, but since I use back button focus, and often prefer spot metering, the inability to lock the focus point is a constant irritation, as the position of the control is such that it's very easy to move it by accident just when handling the camera.
I wish you could remove the L lever whole,  and send it to me!
Re: Lock that "L"!
« Reply #3 on: October 02, 2016, 03:56:54 »
Thanks, Hugh, for the comment.
Yes, I also keep several different tapes near at hand for various purposes.  Double-sided adhesive is handy when you want a clean look.
LOL!  I would be willing to send your the L lever if ever possible.  I guess the small size of D3200 would contribute your problem: the 4-way switch can easily be touched with your thumb or the root of the thumb when you just grab the camera.
Re: Lock that "L"!
« Reply #4 on: October 02, 2016, 05:57:55 »
very useful :o :o :o
i always lock the L switch but sometimes i would use it when i use AF lenses ::)
Re: Lock that "L"!
« Reply #5 on: October 02, 2016, 07:03:12 »
I sometimes lock the L switch but quite infrequently. I sometimes inadvertently lock it and I've lost photos. Most often I try to use it when the camera is in review mode. I'm trying to learn to touch the shutter release to cancel the review mode. I haven't tried it but I'd think the new focus joystick would be a big improvement.
Re: Lock that "L"!
« Reply #6 on: October 02, 2016, 10:03:49 »
Rick, apparently you can manual focus with the old MF Nikkors without problem.   8)
Dave, I use the 4-way switch not only to move the AF points around but also to scroll around the image to review.  So, locking the "L" makes the camera even more stress-free for me.
The joystick of D5/500 is tactile.  I would then wonder how to split the function between the joystick and 4-way switch...   ::)
Re: Lock that "L"!
« Reply #7 on: October 02, 2016, 18:12:05 »
I never use off-center AF points, so I keep the Lock lever locked, unless needs to be unlocked, which is pretty much never.   On the Nikon DLSLRs I have/have had, keeping the switch in 'Lock' does prevent changing the AF point, but does not prevent navigation of the enlarged review image.
Re: Lock that "L"!
« Reply #8 on: October 02, 2016, 18:20:14 »
Akira, I hear you clearly. I never locked it either and on occasion when I do move it to the L position - furious is what I feel when I realise it  :D
Re: Lock that "L"!
« Reply #9 on: October 02, 2016, 18:58:46 »
Thanks, Keith, for confirming the function.  I didn't remember how the position of the "L" lever affects in the review mode, and I cannot make sure of it anymore.  :D
Yes, furious is the word!  :D
Re: Lock that "L"!
« Reply #10 on: October 02, 2016, 19:15:43 »
I intentionally lock the af point when working in studio because my nose presses the af location control
Re: Lock that "L"!
« Reply #11 on: October 02, 2016, 19:27:04 »
Armando, I wonder when you would need to hold the camera at an angle of 30-45 degree?   :o :o :o
Re: Lock that "L"!
« Reply #12 on: October 02, 2016, 21:35:03 »
No need , I use my left eye , so my nose is all over the rear of the camera  ::)
Re: Lock that "L"!
« Reply #13 on: October 02, 2016, 21:42:28 »
I realize that the 4-way switch of D800 is a bit closer to the screen due to the absence of the articulating frame.  Indeed the nose can push it inadvertently, but strangely I have never heard of such a user report...   :o
Re: Lock that "L"!
« Reply #14 on: October 02, 2016, 21:49:12 »
Here is another report of such a phenomenon, but not with every camera. I get the D200 cursor to move, but not the Df with my nose, because I too use my left eye :)
But it's not a problem because I see the red bold rectangle rushing from right to left before my eyes  ;D
