Author Topic: Sticky: Test Display of Image Size: 1200, 1000 & 800 px  (Read 31350 times)
Andrea B.
  • Technical Adviser
There are 3 image attachments posted in this thread of dimensions 1200 x 1200 px, 1000 x 1000 px and 800 x 800 px. You can use them determine how your monitor+browser combination displays the images.
NOTE:  Your results may vary due to your particular monitor display setting and browser choice.
Image: 1200 x 1200 px.
My Laptop:  MacBook Pro Retina
My Laptop Display Setting: 1900 x 1200 px.
My Browser: Firefox - fully expanded, sidebars closed.
SMF Software 'Page View' Setting - Image resized to fit topic: Downscaled 1000 x 1000 px image must be scrolled to see top/bottom.
Right Click and *View Image - Image resized to fit screen: Entire downscaled image can be seen with no scrolling.
Click Again on Image: Image enlarges back to 1200 x 1200 and requires scrolling to see top/bottom.
*In Safari, Right Click and select Open Image in New Tab.
Andrea B.
  • Technical Adviser
Re: Permanent Test: Image Size 1200, 1000 & 800
« Reply #1 on: June 25, 2015, 16:44:30 »
Image: 1000 x 1000 px.
SMF Software 'Page View' Setting - Image already at max topic size, no downscaling: 1000 x 1000px image must be scrolled to see top/bottom.
Click Again on Image: Image enlarges back to 1000 x 1000px and may need to be scrolled to see top/bottom.
Andrea B.
  • Technical Adviser
« Reply #2 on: June 25, 2015, 16:44:49 »
Image: 800 x 800 px.
SMF Software 'Page View' Setting - Image under max size, no downscaling:  Entire 800 x 800px image can be seen with no scrolling.
Right Click and *View Image - Image not resized: Entire 800 x 800px image can be seen with no scrolling.
Click Again on Image: Nothing happens because entire image is already visible.
Andrea B.
  • Technical Adviser
Re: Sticky: Test Display of Image Size: 1200, 1000 & 800 px
« Reply #3 on: August 16, 2016, 23:55:08 »
« Reply #4 on: August 17, 2016, 00:00:49 »
1200, 1000 and 1400 are displayed at the same size with Safari, 800 is a bit smaller... (iMac 21,5", OS 10.11.6 Safari 9.1.2 )
Andrea B.
  • Technical Adviser
« Reply #5 on: August 17, 2016, 00:04:54 »
The maximum Simple Forums software page display size is a 1000 x 1000 px box.
If you right click the image, select View Image and then click the image, you should be able to see a larger size IF your browser is fully expanded with no sidebars.
I'm not sure what the upper limit on View Image size is. Or how it is determined.
On Firefox, I can see the full 1400 x 1400 px when clicked up in the fully expanded browser.
« Reply #6 on: August 17, 2016, 00:10:22 »
I don't have that "right click" option on Safari (no view image)...  :(
Andrea B.
  • Technical Adviser
« Reply #7 on: August 17, 2016, 00:15:40 »
Using Safari, right click and select Open Image in New Tab or Open Image in New Window.
That is the equivalent of View Image in Firefox.
« Reply #8 on: August 17, 2016, 00:26:30 »
Aha... OK Thanks... ;) Still my 2013 iMac has the browser window full open and it limits the size of those views. When I'll retire I'll get the latest 4K screens (or whatever)  ;D
Thomas Stellwag
« Reply #9 on: September 01, 2017, 10:56:08 »
Firefox, Nec Multisync 221
1200x1200 scaled down to 1000x1000
means 1200 and 1000 have the same size, 800 is smaller
Thomas Stellwag
Andrea B.
  • Technical Adviser
« Reply #10 on: November 29, 2017, 20:49:11 »
Update: 29 Nov 2017. Edited for clarity.
