Author Topic: Quoting  (Read 6895 times)
Mike G
Quoting
« on: August 23, 2016, 18:35:20 »
Please teach me how to take and or extract a quote from somebodies post and then put it in my post. Thankyou.
Re: Quoting
« Reply #1 on: August 23, 2016, 18:44:30 »
When you post, previous posts are shown below. Mark the text you want to quote from any of these and click the "Insert quote" button. That's it.
If you get too much of the text, just remove it in your own post before submitting it. just make sure you don't delete the quote tags (in brackets).
You can make quotes from one or more posts several times,
Please teach me how to take ....
It is customary to put an ellipsis ... where you have removed part of the quoted text, to indicate something has been left out.
Thus, using your post again as an example,
...  extract a quote from somebodies post ... . Thankyou.
Re: Quoting
« Reply #2 on: August 23, 2016, 18:45:16 »
There may  be a better way, but I do it by using the quote button and simply erase everything except the portion I intend to quote.
Re: Quoting
« Reply #3 on: August 23, 2016, 18:51:16 »
Same procedure as I described, Tristin, so you are doing the right thing :D
Do remember not to delete the 'quote' or '/quote' tags otherwise your entire post will look like a quote itself.  Any moderator will edit to restore the missing tag (if possible), but we rather see this not being required !! It's not always obvious what error has been committed.
Mike G
Re: Quoting
« Reply #4 on: August 23, 2016, 20:49:13 »
[quoteBjorn Rørslett ]
[/quote]
Let's see if I've got it right!
Re: Quoting
« Reply #5 on: August 23, 2016, 20:52:00 »
Almost but no cigar.
Quote from: Bjørn Rørslett
You need to include the field author=<name> in the opening quote.
Thus incorrect 'quoteBjorn Rørslett ' correct 'quote author=Bjørn Rørslett '
(I used ' instead of the square brackets to avoid upsetting our forum software)
Mike G
Re: Quoting
« Reply #6 on: August 23, 2016, 21:10:27 »
That looks a bit better!
Re: Quoting
« Reply #7 on: August 23, 2016, 21:11:31 »
Mike, you shouldn't alter any texts in the brackets.  And you should add your reply outside the HTML brackets.
Re: Quoting
« Reply #8 on: August 23, 2016, 22:58:59 »
Here is a quote...
Here is what happens if I delete the first and last [] square brackets...
quote author=Akira link=topic=4187.msg64713#msg64713 date=1471979491]
[/quote
Here is what happens if I do not disturb the first and last complete quote tags but delete one sentence in between...
...  And you should add your reply outside the HTML brackets.
Consider the opening and closing tags as sacred!
I'm lazy and let the quote button write the BBCode for me.
Hope this helps,
Here is a link if you want to fight the BBCode yourself...
https://www.phpbb.com/community/faq.php?mode=bbcode
Re: Quoting
« Reply #9 on: August 23, 2016, 23:04:13 »
Those are what the Mods have to put into sensible places when something seems amiss. However, if too much of the tag structure is deleted, it can be quite difficult to understand what is quoted and what is newly added stuff.
Therefore, do heed Dave's warning. Never touch opening or closing tag.
Mike G
Re: Quoting
« Reply #10 on: August 24, 2016, 08:34:28 »
Bjorn, thanks for the pointers. My problem was that I'd forgotten how to do a quote, bloody hell it seems so obvious when somebody shows you how to do it :-[
Re: Quoting
« Reply #11 on: August 24, 2016, 08:41:30 »
Memory lapse can happen to the best of us, don't give up Mike.
We are there to help.
Re: Quoting
« Reply #12 on: August 24, 2016, 10:33:07 »
They also happen to the worst of us.  :(
Mike G
Re: Quoting
« Reply #13 on: August 31, 2016, 20:20:25 »
Thanks Bjorn, having reread my reply it didn't make sense soI amended it a bit.
I think I'll retreat to a corner and dribble into my tea :-X
Re: Quoting
« Reply #14 on: August 31, 2016, 22:20:57 »
Quote from: Quoth the raven
Nevermore...  :(
