Author Topic: [Theme]bridge  (Read 34259 times)
Re: [Theme]bridge
« Reply #45 on: April 23, 2017, 11:53:08 »
Selfie from the bridge
Df, 24mm f/1.4g
Re: [Theme]bridge
« Reply #46 on: April 23, 2017, 12:02:27 »
Zaanse Schans
Df, 24mm f/2.8ais
Mike G
Re: [Theme]bridge
« Reply #47 on: April 23, 2017, 12:49:03 »
Fons, is the cheese dairy and the clog maker still at Zaanse Schans?, I haven't been there for nearly 25 years now, but I do remember three windmills and that it was freezing cold in April!
Re: [Theme]bridge
« Reply #48 on: April 23, 2017, 12:59:53 »
Cheesemakers are still there and April this year is still very cold, i have been to Zaan only this once :) a few years ago now in November 2015 it was.
Re: [Theme]bridge
« Reply #49 on: April 23, 2017, 13:02:39 »
De Rijp that same day
Re: [Theme]bridge
« Reply #50 on: April 23, 2017, 15:17:50 »
African jungle crossing (IR)
Re: [Theme]bridge
« Reply #51 on: April 23, 2017, 17:14:35 »
D800, nikkor 85mm f/1.4 ais wide open, sharp lens.
CS
Re: [Theme]bridge
« Reply #52 on: April 23, 2017, 17:44:31 »
F3HP- 50 f1/.4
Carl
Lars Hansen
  • Zealand, Denmark
Re: [Theme]bridge
« Reply #53 on: April 23, 2017, 19:27:30 »
Yes, from the Sjælland side. There is a lay-by before the bridge that allows unrestricted view of the strait and the bridge. Vantage point is very low, though.
If you walk under the bridge and approx 250 meters longer north you can get a bit higher on a moraine hill but from that vantage point the bridge will be backlight unless you are there in the evening.
#1 Moraine hill seen from under the bridge.
#2 Just to give an impression of the distance and vantage point - shot from the hill - APS-C / 35mm (approx)
#3 A twisted view of the bridge.
Re: [Theme]bridge
« Reply #54 on: April 23, 2017, 20:56:21 »
Well ... uhm ... wow !
One from Rotterdam, Erasmus bridge from Euromast tower.
Re: [Theme]bridge
« Reply #55 on: April 23, 2017, 21:21:20 »
U-O, bridges, that's some theme!
Very nice images so far.
becoming a bridge (Hålogaland Bridge; construction site, route E6, Lofoten, Norway)
Re: [Theme]bridge
« Reply #56 on: April 23, 2017, 23:23:48 »
Germany
Re: [Theme]bridge
« Reply #57 on: April 24, 2017, 20:45:18 »
Burgers Zoo, Arnhem
Re: [Theme]bridge
« Reply #58 on: April 30, 2017, 13:23:58 »
Re: [Theme]bridge
« Reply #59 on: May 01, 2017, 01:31:13 »
The bridge.
Nikon D40X, SUNEX 5.6 mm f/5.6
