Author Topic: Projection lenses  (Read 132855 times)
Re: Projection lenses
« Reply #120 on: March 18, 2017, 23:59:36 »
Thanks guys!
Nice shot John!
« Reply #121 on: March 19, 2017, 09:28:23 »
Thanks Klaus.
You have a somewhat complete overview of all Projection Lenses?  Or are there still a lot of 'discoveries'?
« Reply #122 on: March 19, 2017, 09:40:42 »
Thanks Klaus.
I have a few, but there are so many on the market which have been made by different lens makers.
Basically all optical companies have made them since decades if not centuries, dating back to Petzval
which still is a very common lens design for projection lenses. There are still discoveries to be made
and cheap ones to be found (especially russian ones), although the prices went up considerably since
the "hype" started and I also plead guilty for that trend... ;-)
« Reply #123 on: March 21, 2017, 22:29:19 »
(Meopta Meostigmat f1.3 50mm projection lens)
« Reply #124 on: March 21, 2017, 23:19:59 »
Dr. Klaus,
you keep on making and sharing this amazing images.
  Thanks!
« Reply #125 on: March 23, 2017, 16:36:42 »
Dr. Klaus,
  Thanks!
You could do same Paco, just need some 65mm focusing helicoid, two adapters (one camera, one lens)
and a rather cheap russian projection lens, and you're all set to go!
« Reply #126 on: March 27, 2017, 00:57:47 »
Light in the Darkness
(CZJ Visionar f1.6 100mm + Speedbooster = f1.1 70mm )
« Reply #127 on: March 27, 2017, 01:21:05 »
(CZJ Visionar 1.6/100mm + Speedbooster = 1.1/70mm)
« Reply #128 on: March 28, 2017, 17:24:32 »
(Old Hermagis 80mm projection lens, Petzval type)
« Reply #129 on: March 28, 2017, 19:07:10 »
Now you are provoking... ;D ;D ;D
« Reply #130 on: March 28, 2017, 21:02:33 »
Yep, on purpose. In Asia those lenses with that draw call a massive premium....
Just wanted to show what a century old french projection lens can do...
(in a situations deliberately chosen and designed to cause such special bokeh)
« Reply #131 on: March 29, 2017, 18:12:13 »
Sweet Almond
Slovenian Cherry
Magnolia
Spring Anemone
Daffodil
Imperial Fritillary
(CZJ VISIONAR 1.9/154mm)
« Reply #132 on: April 11, 2017, 00:10:16 »
(B&L Super Cinephor f1.8 146mm)
« Reply #133 on: April 11, 2017, 01:00:47 »
(B&L Super Cinephor 1.8/146mm)
Andrea B.
  • Technical Adviser
« Reply #134 on: April 11, 2017, 02:16:54 »
The Hermagis 80 photos are amazing!!! I want one of those.
