Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
*** Welcome to the new NG Server ***
Current status:
106/150
supporters
Home
Help
Login
Register
NikonGear'23
Gear Talk
What the Nerds Do
Chipping the Rodenstock Heligon 100/1.6
« previous
next »
Print
Pages: [
Go Down
Author
Topic: Chipping the Rodenstock Heligon 100/1.6 (Read 2626 times)
stenrasmussen
Guest
on:
April 08, 2016, 09:01:02 »
Thanks to our CPU maker I am in the process of making said lens proper-compatible with my Nikons.
My sample is sunk into a 18-70G shell and pushed back so far that I achieve focus as a distance of ca. 1.3 meters.
In order to fit the contact block I will need to modify another bayonet. The one I originally had in place was grinded slimmer which prevented a correct position of the contact block.
I believe the bayonet I'm going to use is from a wrecked Tamron 19-35 (which by the way has its outer shell duct taped in place to act as a lens shade for the Heligon).
Here are some shots of the patient...more to follow.
Logged
Fierce Bear of the North
Administrator
Oslo, Norway
Re: Chipping the Rodenstock Heligon 100/1.6
Reply #1 on:
April 08, 2016, 09:48:24 »
A duct-taped lens .... you are qualified for the geeky part of NG by a wide margin, Sten !!
Do keep us updated on any progress, please.
Logged
https://www.flickr.com/photos/132961550@N03/
Global Moderator
Copenhagen
Reply #2 on:
April 08, 2016, 11:50:55 »
So is there room for this - or will it go into the 'blur circle'?
Logged
stenrasmussen
Guest
Reply #3 on:
April 08, 2016, 14:54:51 »
Voila...although I had to grind into the rear element the image circle is big enough.
Time for some images:
Logged
stenrasmussen
Guest
Reply #4 on:
April 08, 2016, 14:56:47 »
Here's the pudding proof, no blur circle interference.
Logged
stenrasmussen
Guest
Reply #5 on:
April 08, 2016, 14:58:50 »
Forgot to mention that the CPU makes life muuuuch easier on my D5300...which may become my next IR camera. The obstacle is the monocoque body which makes disassembly a little trickier. Thanks Bjørn!
Logged
Global Moderator
Copenhagen
Reply #6 on:
April 08, 2016, 15:57:39 »
Very nice work as always! Super
Logged
Administrator
Oslo, Norway
Reply #7 on:
April 08, 2016, 16:40:10 »
Sten is now officially a
Certified NG Nerd
Congratulations.
Logged
charlie
NG Supporter
Reply #8 on:
April 08, 2016, 18:09:23 »
Nice work, Sten. Thanks for sharing.
I it looks like I've got the same Dremel drill press as you
Logged
Jakov Minic
Global Moderator
The Hague, The Netherlands
Reply #9 on:
April 08, 2016, 21:31:49 »
Well done Sten!
Dr Lens II does it all again
Logged
stenrasmussen
Guest
Reply #10 on:
April 11, 2016, 19:56:26 »
Thanks girls
Tis like I want to craft a doctor diploma to decorate my office wall with now...mwahahaha....
Logged
Print
Pages: [
Go Up
« previous
next »
NikonGear'23
Gear Talk
What the Nerds Do
