How could I forget to mention the 105/2.5....
I tend to use the Leica mount version more than the F-Mount version...
Nice lens collection, sir, and interesting ... thanks.
My definition of "Old School" tends to be anything pre-1960.
Would have to disagree ...
You're confusing old
school with just plain
old.
Old = chronological age.
Old School = modern item with elder design.
Most modern lenses are electronically-driven ... so a modern lens, with ZERO electronic gadgetry = "old school" design, as in the old days
The Nikkor-P 10.5cm F2.5 (Sonnar original) version was designed to be under-corrected for spherical aberration, ie smooth Bokeh. The rangefinder version has a rounded aperture using 10 blades, the F-Mount version has less blades. The optical formula changed in the early 70s.
Interesting, thank you.
I can tell I have
a lot to learn
The F-Mount Ai version is back row, to the right. These can be bought for under $150.
The 200mm F4 Ai and Ais lenses are compact, and can be found for $100 or so. Some threads just started on them. Some samples here:
Wow
Very good lenses for a few hundred ... maybe I'd better spend some more time on eBay
Thanks for the photos and input,
Jack
