Author Topic: Nikon D5 - first impressions  (Read 147059 times)
Re: Nikon D5 - first impressions
« Reply #135 on: March 26, 2016, 23:52:08 »
Thanks for the update! Looking forward to more ;)
James Farrell
  • Prescott, Arizona, USA
    • My Smugmug Site
« Reply #136 on: March 27, 2016, 00:01:14 »
On page 99 and 100 of the english version of the user manual, Nikon lists some graphs and data on the interaction of lens types, TC combinations with lenses and their respective implications on the number of available AF cross sensors.
In a nutshell, the 500mm/f4 and 200-400mm/4 lenses can only use the center field AF cross sensors(with the exception of the 500mm FL version), the 600mm/f4 in addition one row of outer AF cross sensors on each side (no exception for the 600mm FL). Most other lenses below f4 have the full coverage of AF cross sensors.
please refer to the D5 manual for more detail (don't want to copy the 2 pages into the thread)
rgds, Andy
Andy (and anyone else): I saw this table in the D5 manual a few days ago and it raised some questions. I don't understand why my Nikon 200-400 f/4 VR-2, for example, is limited to the 45 center AF cross sensors. That said, I do understand that when one adds a teleconverter that starts to limit the number of cross sensors. But why would a "naked" lens (i.e. no teleconverter mounted) of the caliber of the 200-400/4 VR-2 be limited in use of AF cross sensors? I must be missing something (not unusual). Thanks in advance for helping my senior-citizen brain try to understand this.
Jim F. from Prescott, Arizona
Andy
« Reply #137 on: March 27, 2016, 11:00:55 »
Yesterday,
I've provided Bill Claff more and other test images he asked for last week. To further his as usual very good and insightful analysis - this time about the read noise of the D5 sensor.
Plus, pls also see Marianne Oelund's comments in the thread @dpreview.
Here is his first take (of the second part) of it:
http://www.dpreview.com/forums/thread/3983969
Here is the first part, for those who are interested:
http://www.dpreview.com/forums/thread/3981547
rgds, Andy
Vilhelm
  • Mr.
  • Gone fishing
« Reply #138 on: March 27, 2016, 19:12:28 »
My wish concerning this post: Please someone compare D3, D4, D5 output side by side visually
Don't have a D3, but I have a D4S and the above requested comparison is so time-consuming that I am confident some professional gear blogger will do it. I don't have the gear nor the time to complete such a comparison.
I got my D5 last Thursday, and have since been shooting with it. I always felt with the D4 that ISO 8,000-9,000 was the maximum acceptable quality, with the D4S the same quality maximum was set at ISO 18,000-20,000. With the D5, I find that ISO 40-64k is fine and depending on dominant color channel even ISO 80,000 looks acceptable, with the same quality standards (noise/detail/grain).
This is ISO 64,000 on a D5. I really really have difficulty in grabbing the D4S for a photoshot, now that I am growing accustomed to the D5 performance
Life isn't about finding yourself. Life is about creating yourself.
- George Bernard Shaw
dibyendumajumdar
« Reply #139 on: March 27, 2016, 22:15:04 »
Hi - thanks for posting the samples from D5. I am curious about the D5's AF system's accuracy with F1.4 lenses as compared to the D4. Has there been any improvement in this regard?
Thanks and Regards
Dibyendu
Vilhelm
  • Mr.
  • Gone fishing
« Reply #140 on: March 27, 2016, 23:21:03 »
This is somewhat confusing to me, did the D4/D4S have problems with focus accuracy on f/1.4 lenses? I never experienced that.
I've used the D5 for 4 days now, of which only one day was real work. Can't say too much of the AF other than that it feels better than what I was used to when focusing on moving targets (used to = I used a D4 and D4S before)
dibyendumajumdar
« Reply #141 on: March 27, 2016, 23:41:13 »
Hi - I found focusing on moving targets at F1.4 was not accurate/reliable. This is also stated by Rob Galbraith in his review of the D4 (http://www.robgalbraith.com/multi_page9056.html?cid=7-12721-12406). I understand that this is a known issue in that the AF system in Nikon cameras was designed with F2.8 and below in mind - please also see this thread by Marianne Oelund (http://www.dpreview.com/forums/post/54211961).
Since the D5 has a new AF sensor I was wondering if AF with faster lenses has improved.
Regards
Dibyendu
« Reply #142 on: March 28, 2016, 00:30:07 »
With all due respect, the 1.4 AFS lenses focus just fine on D3, D3X, D4 and D810 IMHO
They are not as fast focusing as the Pro f/2.8 zooms but there is another reason for that.
Andy
« Reply #143 on: March 28, 2016, 01:27:37 »
Thanks and Regards
Dibyendu
Dibyendu,
the answer is the usual yes and no :)
Depending of the lens/camera combo, the D5 is sometimes like a few of my other bodies off the focal plane with a few fast lenses (Please consider that Nikon calibrates AF systems with a 50mm/1.4 reference lens set at f2.8. I heard this back in 2011). I had a few of my bodies and fast lenses travelling mutiple times to Nikon's service facility in Dusseldorf in 2011 (the whole process took more than 2 months and brought forward the spectral sensitivity of AF systems built into the D3/D3s/D3X/D7000, plus a few other gimmicks. The spectral issue had been fixed in the D4/D800 generation. More info on this exercise in german language). This is the bad part.
The good part is, that fixing it with the D5 is a sneeze vs. the previous cameras.
The Auto AF fine tune is described in the Menu Guide on page 110 (The Menue Guide is only available as PDF, it is not in the box. There is only the User Manual as printed doc)
Correcting the AF of a lens takes about 5 seconds (*) if you have a proper target (i.e. a vertical plan sheet). The AF is then not "perfect" in the pixelpeeper sense (neither is the Live View AF always 100% correct at this level), but it is as simple as to be very valuable that you can do it on the fly when needed.
rgds, Andy
(*) 5 seconds is now the time it takes to set AF when the camera is on a tripod. It is really simple.
but ....
My first attempt took roughly 30 mins, I was close on raising a service request for help :(
1) I couldn't find the AF fine tuning button sequence in the user manual. There is no mentioning on auto AF fine tune in the D5 User Manual.
2) There was info in the internet that the button combination was (AF-mode) and (shutter release) - but that didn't work ...
3) When I figured out that it was covered in the downloaded Menu Guide, the right button combination to press is "AF-mode" and "Video-Rec"
4) Then the error message popped up every single time "Auto AF fine tune is not available at current focus setting" and didn't let me store the adjustment value
5) The culprit was the focus selector in LiveView mode: It has to be *exact" in the center of live view field. Putting it approximate there doesn't do the trick. Pressing the OK button in LiveView to put it perfectly in the center did the trick and brought me over the finish line that I could store the AF compensation value.
6) Now it is really a short and convenient process
rgds, Andy
« Reply #144 on: March 28, 2016, 08:50:04 »
Thank you Andreas. That is a very good argument for the D5 and D500.
Fast prime performance suffers most from not fine tuned AF.
A 5 second fix is a viable solution.
Andy
« Reply #145 on: March 28, 2016, 10:39:17 »
Marianne Oelund started a thread "D5 - New features and Issues"
http://www.dpreview.com/forums/thread/3984292
Initial comments on:
High-ISO Image Quality, camera JPEGs
AF speed/consistency
New Advance Mode Control
LCD and Viewfinder display changes
Menu display of folder number
Folder names
Playback Image Numbering
AF Fine Tune Default range
Third-party lens issue
On XQD readers - just seen @NFF:
With the initial batch of D5 comes a Sony XQD card and a card reader. Pls consider that the with the D5 supplied Sony card reader QDA-SB1A can't read the "old" XQD cards we used to have with the D4 (The "H" Series). There is another card Sony reader MRW-E90, which can read all XQD card models. Sony XQD speed and compatibility list: http://www.sony.net/Products/memorycard/en_us/xqd/
rgds,
Andy
Tersn
    • On Flickr
« Reply #146 on: March 28, 2016, 10:52:09 »
rgds, Andy
but ....
rgds, Andy
Thanks, for sharing this useful info, Andy! It is hard to understand why Nikon made it so difficult to find it and why they failed to be mentioned it in the D5 User Manual etc.  :o
Terje S.
Marc
    • africaddict
« Reply #147 on: March 28, 2016, 15:08:24 »
rgds, Andy
but ....
rgds, Andy
Many thanks for this Andy,
I too was looking for AF Auto tune in the manual and was going nuts why I couldn't see it, so appreciate your investigations!  ;D
Regards
Marc
dibyendumajumdar
« Reply #148 on: March 28, 2016, 22:36:23 »
@Erik and @Andy - thank you for the responses.
Andy
« Reply #149 on: March 28, 2016, 23:04:35 »
DPReview published their first D5/D4s StudioComparisonHighIsoNoiseScene
http://www.dpreview.com/news/0715893019/nikon-d5-studio-scene-comparison-published
http://www.dpreview.com/reviews/image-comparison/fullscreen?attr18=daylight&attr13_0=nikon_d5&attr13_1=nikon_d4s&attr13_2=canon_eos1dx&attr13_3=sony_a7sii&attr15_0=jpeg&attr15_1=jpeg&attr15_2=jpeg&attr15_3=jpeg&attr16_0=100&attr16_1=100&attr16_2=100&attr16_3=100&attr171_2=off&attr171_3=off&normalization=full&widget=1&x=-0.0030276816608996904&y=-0.0014892443463871783
I would not be surprised if over time we will see 2 trends:
1) The internet community interpreting valid measurements asking the "Why shall I upgrade question".
2) In the same time users are enjoying the combined capabilities of the new tool.
This raises potentially two related questions:
1) Do we need better measurement metrics reflecting a new broader set of emerging attributes (noise pattern design, SW processing algorithms, ease of producing a "final" image, etc ....) or,
2) are users increasingly decoupling their "user experience" from underlying and existing "hard" metrics?
Hmmm, what's your view?
rgds, Andy
