Author Topic: Butchering a Noct-Nikkor 58 mm f/1.2 AI  (Read 32268 times)
Re: Butchering a Noct-Nikkor 58 mm f/1.2 AI
« Reply #15 on: November 28, 2015, 17:28:49 »
just a simple extra notch in the ring  ;) It seems an 50mm 1.2 Ai has this by birth... Ais doesn't...
Bjørn Jorde
« Reply #16 on: February 24, 2016, 05:11:50 »
Erik & Bjørn,
From the description and pictures of the chipping of the Noct,
Looks like the 50 1.2 AIS would entail a similar butchering?
BJ
« Reply #17 on: February 24, 2016, 05:27:22 »
They report the 50mm f/1.2 Ai-s as not really being chippable due to lack of space inside it.   :'(
http://www.naturfotograf.com/lens_CPUconversion.html
« Reply #18 on: February 24, 2016, 05:56:36 »
yes, that is actually annoying because I cannot have something in between f/2 and f/2.8  :o :o :o
for 1.2 lenses, there is a big jump in the way things are rendered, 1/2 stop goes a long way in big apertures.
« Reply #19 on: February 24, 2016, 06:16:38 »
Richard, could not agree more.  When I have the funds to get my 105mm chipped I will be sending my 50mm f/1.2 along to be getting f/2.4'd.  I wish it had f/22 as well.
« Reply #20 on: February 24, 2016, 07:07:10 »
Tristin, you may have missed this recent posting in respect of using a Dandelion chip - it seems that there is at least enough space (just) on the outside to chip the 50mm AiS f/1.2 with this alternative chipping technology.
Link: http://nikongear.net/revival/index.php/topic,2860.msg38545.html#msg38545
The proof that you can fit a Dandelion to the 50/1.2 AIS. Erik at his best :D
This method of attaching the Dandelion alleviates most if not all problems and weakness of the usual positioning, in which the chip will be exposed to excessive wear and tear. Still, the pins are on the long side so their tips will wear rapidly.
« Reply #21 on: February 24, 2016, 09:09:38 »
That's good news.  We'll see how Bjørn's holds up.
« Reply #22 on: February 24, 2016, 09:37:42 »
The Naturfotograf.com pages has not been updated for years, so  please use them as such, time moves on ;)
This thread is about using one of Bjørns CPU's - inside a long Nikon CPU contact block to chip the Noct-Nikkor, as can be deducted I first did it on my own Noct-Nikkor an Ai - It was extremely difficult to create the needed volume and many different solutions where discarded in the process,,,
But in the end I got it to work, the most important was that it retained the out of focus blur circles round and intact so the optical quality was intact, Bjørn tested this on the scavenger tour,,,
Several times after this Bjørn asked me to chip his lens as well, this thread is the chipping of his Noct-Nikkor Ai.
I believe I have chipped one more, I forgot who,,,
I have chipped several 50mm Ais 1.2 with Dandelion CPU, by cutting the integrated light-baffle on the F-mount and it was quite neat solution since only a little bit of the rear element housing needed a trim, but still this is a rater fragile solution,,,
Later I wanted to chip my own brand new 50mm 1.2 Ais and it occurred to me that the Dandelion contacts and electronics could fit inside the integrated metal light-baffle.
I chopped up a Dandelion so only the pins, electronics and the rear of the contact block was left and hollowed out the light baffle, drilled the 5 holes for the contact block and used epoxy glue to the inside of the light-baffle. Then I removed as much of the rear of the contact block as much as possible, then trimming down the rear element housing as little as possible - A really strong solution.
Here is an image of the lens http://nikongear.net/revival/index.php/topic,2860.msg38545.html#msg38545
This was a lot of very delicate work, surgery on a mosquito comes to mind  :o
Bjørn came around and tested the lens, liked it and traded it for a 50mm 1.2 Ai then took it to Nikon Nordic, they tested the position of the pins, they where all within factory specification, actually spot on.
The 50mm 1.2 Ai has a larger rear element so it would need a lot of trimming to fit the CPU, similar to a Noct - So actually not worth all the work,,,
Today I would suggest to use a the 50mm 1.2 Ais Dandelion chipping method on a Noct-Nikkor - But it doesn't give as many parameters as Bjørns CPU does,,,
« Reply #23 on: February 24, 2016, 09:41:44 »
These 'slots' for 1/3 or 1/2 aperture stops are very easy to ad to the aperture ring.
« Reply #24 on: February 24, 2016, 09:44:57 »
I'm quite sure it would be easy on most lenses that only go to f/16 to create the f/22 stop, it's a matter of trimming the stop inside the Aperture ring and cutting a slot - But diffraction has a huge impact on sharpness already from f/11 so IMHO it would not make sense to do it.
« Reply #25 on: February 24, 2016, 09:59:46 »
gonna grind those slots when the warranty for this lens is gone  :o :o :o
i bought mine new because Nikon is selling them new here cheaper than used ones in the market  ::)
« Reply #26 on: February 24, 2016, 10:12:09 »
Erik's ingenious solution removes the delicate and fragile character of the Dandelion. The modified lens has survived many field ordeals without any issues, so longevity is assured it seems. Only in the highly unlikely case of the epoxy breaking up, or one of the pins wear down, might it fail.
« Reply #27 on: February 12, 2019, 15:24:23 »
Ooops - actually the latter scenario manifested itself. One of the dandelion pins jammed and then ripped everything out with it. Erik being my big hero kept the lens for a rainy day and silently fixed it so surprised me with a "new" 50/1.2 on our next meet-up. That's what I call a friendly gesture :D
Macro_Cosmos
    • Flickr
« Reply #28 on: March 29, 2019, 12:57:36 »
I'm wondering if it is possible to chip my Thorlabs SM2-F-mount adapter with one of these to display stuff like "Mitutoyo M Plan 10x Apo NA/0.28", would the text be too long? I have the 5x, 10x and 20x objectives.
Blog: Diatoms Australia
« Reply #29 on: March 29, 2019, 13:45:43 »
I identify my Mitutoyo objectives by the equivalent focal length and aperture (CPU chip), then my database software does a table look-up to fetch the complete text which then is inserted in the image record. The EXIF only stores a pointer not the full text.
