Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
*** Welcome to the new NG Server ***
Current status:
106/150
supporters
Home
Help
Login
Register
NikonGear'23
Gear Talk
What the Nerds Do
DIY AI Conversion!
« previous
next »
Print
Pages: [
Go Down
Author
Topic: DIY AI Conversion! (Read 3547 times)
Cute Panda from the East...
NG Supporter
Your lens loverboy
DIY AI Conversion!
on:
February 05, 2016, 07:19:15 »
http://richardhaw.com/2016/01/21/diy-ai-conversion/
Hi! just sharing my blog post on how I convert my pre-Ai lenses using a dremel
I hope that you enjoyed it!
Logged
99 luftballons
Fierce Bear of the North
Administrator
Oslo, Norway
Re: DIY AI Conversion!
Reply #1 on:
February 05, 2016, 08:31:06 »
Thanks for the article, Richard. You earn 1 NG Nerd Star (*)
Logged
https://www.flickr.com/photos/132961550@N03/
NG Supporter
Your lens loverboy
Reply #2 on:
February 05, 2016, 08:43:38 »
thank you! i swear that i would have bought a table top lathe so that i could even turn rings and converters for my lenses! currently, i am just turning my extension rings from a dremel! japanese landlords are strict, specially with noise at night and what you do within the house
Logged
99 luftballons
Global Moderator
Copenhagen
Reply #3 on:
February 05, 2016, 08:46:45 »
We just had another thread on this subject and I see you make the same mistake in your Blog on Ai convertion
Thread is here:
http://nikongear.net/revival/index.php/topic,2650.0.html
I stated:
For the Aperture ring to work on cameras with 'Minimum Aperture sensor' like on D200 and D40 etc. you also need to cut down the aperture ring to make a second ridge for that to work properly.
The sensor informs the camera that the lens is set to minimum aperture or not... Used for P and S Mode.
If you install one of Bjørns G-Type CPUs no ridges are needed, Since G-Type lenses has no ridges... Not always a good solution since the pre Ai apertures are not always linear - But not all lenses know that...
IMHO the image show how to make a quick and dirty DIY hack that works on some cameras - Not recommended!
Some Pre-Ai aperture rings are a bit short for these mods to work like a real AI or Ais ring, they barely catch the aperture index lever on the camera, so a little extra care when mounting the lens will prolong the cameras aperture index levers life, it's a rather fragile component...
Logged
NG Supporter
Your lens loverboy
Reply #4 on:
February 05, 2016, 08:59:41 »
oh,yes! i for got about that! thank you for pointing that out
i should add that as a follow-up post!
i have not used those bodies so i skipped it (started with the D60 from a canon T60)
Logged
99 luftballons
Print
Pages: [
Go Up
« previous
next »
NikonGear'23
Gear Talk
What the Nerds Do
DIY AI Conversion!
