Author Topic: Just trying to post and image  (Read 1953 times)
DaveO
« on: June 18, 2015, 20:50:40 »
   How do you insert an image on a post here?  Do you have to post it elsewhere like Flickr or into an album on this forum?
David Olsen
Re: Just trying to post and image
« Reply #1 on: June 18, 2015, 20:57:15 »
Use attachments if your image isn't on an external hosting service.
« Reply #2 on: June 18, 2015, 20:59:06 »
dave - I post on Flickr  - as I understand it saves this site bandwidth?
very easy to do via Flickr - just copy the bb something code and paste in in here - and your image will display
I can look the code up if you are stuck - but right now my bandwidth is hogged by uploads and I live in dark africa - speed - ....
edit
its the BBCode - which you find when clicking on the share button of your image on flickr
The_Traveler
    • lewlortonphoto.com
« Reply #3 on: June 18, 2015, 20:59:28 »
click on attachments and other options below this text box.
Lew Lorton
The_Traveler
a non-technical shooter
DaveO
« Reply #4 on: June 18, 2015, 21:03:45 »
I'm not sure what I did to get this attached from my computer.  Just kept doing different things.
These are Mdme Toussaud figures in a castle in England.  I got the wrong image because it has the black lines around it from my scanner.  I cropped it to take them out, but still grabbed the wrong image.
David Olsen
« Reply #5 on: June 18, 2015, 21:06:29 »
Ah well that worked perfectly.
Andrea B.
  • Technical Adviser
« Reply #6 on: June 18, 2015, 21:12:31 »
Looks like I should write up a Guideline for Posting an Image!!
That is now on the TODO LIST.  :D
