Of course the 55 micros can be reversed, but unless you need greater than 1:1 magnification, there is little need. They all perform extremely well down to 1:2, and with the M tube or PK-13 to 1:1. Since these lenses all have near symmetric optical designs, the performance gain by reversing for magnifications beyond 1:1 is only small. The AIS 55/2.8 on the PN-11 will get to nearly 1.5x life size, with the benefit of automatic aperture and AI metering. However, the working distance with this combination is very small.
For 1:4, I like my Zeiss 135 f/2 Apo Sonnar.
For 1:2 - 1:1, I like my Voigtländer 125 f/2.5 Apo-Lanthar (in fact, the Zeiss usually stays at home, and I just use my CV.
My favourite combination for magnifications beyond 1:1 is the AF 105/2.8 micro with the PN-11 tube. This will get to about 1.6x life size with a good amount of working distance. Adding a PK-13 will increase the magnification to 2x. The PN-11 has a built-in tripod mount giving a well balanced and stable setup, and it is easy to change orientation from vertical to horizontal while staying on target. My PN-11 has a Arca-Swiss type quick release plate, I can easily move it forward and back a couple of cm within the clamp (like a short focus rail) to achieve focus once the lens has been set to the correct magnification - very convenient.
I'd only use a reversed lens if I needed to shoot higher magnifications, and then I would choose a shorter focal length otherwise the amount of extension required becomes unwieldy.
For the field, I'll just crop my Zeiss/CV shots for small increments over 1:1.
For the studio, I was using my 50 f/1.2 AI-S, reversed, for 1:1, which was extremely sharp at f/4 (for stacks), but had tons of CA if the setting was right. It is the 50 AI-S I have replaced with the 58mm f/1.4 Voigtlander SL II S Nokton (ordered/shipped today). If I am not satisfied, I will return and try the Micro-Nikkor.
I have not had much luck with biting-sharp field shots over 4-5:1. I think these higher magnifications are better left for the studio, even with flash.
My favorite high-mag lens, for the field, is the 28-50mm f/3.5 AI-S:
It focuses down to 1:4 properly-oriented, and achieves between 1:1 to an almost 3:1 reproduction ratio reversed.
Here is a recent shot at 1:4, properly-oriented:
And here is a shot at ~2:1, with it reversed (this spider could sit on the mantis' forearms):
The Zoom-Nikkor 28-50mm f/3.5 AI-S is not quite as clean as my AI-S primes, and certainly not as clean as my Zeiss/CV Apos ... but it is sharp and clean enough to justify its existence ... especially considering how light, versatile, and handy it is in one package. I can go 28-50mm properly-mounted ... to 1:4 ... then flip it and go 1:1 - ~3:1 as a macro.
One of the handiest little lenses I have ever owned, if not the handiest. If you don't feel like carrying a bunch of stuff, it can get a lot accomplished by itself, and a reverse-ring in your pocket.
