Author Topic: Lightroom CC 2015  (Read 8570 times)
Lightroom CC 2015
« on: June 16, 2015, 22:53:21 »
It seems to be significantly faster than the previous versions, both at startup and when loading photos.
That would be the first significant, quite significant improvement in a long time.
Do you share that impression ?
Re: Lightroom CC 2015
« Reply #1 on: June 17, 2015, 06:23:20 »
I don't use LR but my local friends are particularly impressed with the pano stitching
http://petapixel.com/2015/04/21/adobe-unveils-lightroom-cc-speed-boost-raw-hdr-and-pano-face-finding-and-more/
then some notes by Eric Chan
Camera Raw Engineer :
https://forums.adobe.com/thread/1828580
worth watching as this can save you plenty of time and effort with a selection
https://www.youtube.com/watch?v=LypUUCT7XFQ
« Reply #2 on: June 17, 2015, 11:15:37 »
Downloaded CC2015.  Both 8- and 11- stitching panos using 16MP NEFs from D7000 seem to be a bit faster than in CC2014.
The "Save For Web (legacy)" function is moved to the lower level of the original pull-down menu, but the processing has become much faster.  However, the processing speed of the newer (non-legacy) function seems to be the same as the Save For Web of CC2014.
« Reply #3 on: June 17, 2015, 11:20:14 »
Akira - my friends also say it stitches must better - far less artefacts especially in the sky.
« Reply #4 on: June 17, 2015, 11:39:43 »
Elsa, according to my initial test, the stitcing of the power lines seems yet to be improved on CC2015 over 2014.  So far I only noticed the slightly improved processing speed.
Recently I'm into panos, so I will further look into the accuracy.
« Reply #5 on: June 17, 2015, 12:09:47 »
Lightroom 6/CC had serious problems with importing .TIFF files from Photoshop or other software. It was very disappointing and a huge hassle for those of us who jump back and forth from Photoshop to Lightroom. Yesterday, Adobe released a fix Lightroom CC 2015.1, and that did the trick. The new De-Haze filter is wonderful as are the addition of Black and White sliders in the adjustment brush, Radial, and Graduated Filters. Here is a recent photo, just to give us something to look at.
Photo: Nikon D810, Otus 55mm APO f/1.4
« Reply #6 on: June 18, 2015, 13:06:16 »
Airy: On my 15" rMBP from 2013 (model with dedicated NVIDIA GPU), there doesn't seem to be that much of a difference to be honest.
Elsa: Thanks for the links. It's nice to read a more detailed explanation of the GPU performance improvements they have implemented. I still would like to see more info. As far as I know, they are "only" using OpenGL and not OpenCL to speed up performance. Capture One has been using OpenCL for quite a while to speed up image processing and it can really do magic to the snappiness and performance. At the latest Apple developer conference, Apple announced "Metal" for OSX and Adobe was specifically mentioned in that regard. In my limited understanding of Apple's Metal framework, it can replace both OpenGL and OpenCL so perhaps we will see a future version of Lightroom using that instead and get some of the improvements that Capture One has provided for a long time.
« Reply #7 on: June 18, 2015, 14:35:28 »
Jorgen, my first impressions are indeed lessened by further experience, the improvement is not massive. At least it is not worse...
« Reply #8 on: June 18, 2015, 15:00:28 »
I am not seeing the increase in speed via the GPU. I have two GPUs, both 512, correct brand, etc. Kind of disappointing. Coupled with the recently fixed .TIFF problem, which was terrible, not sure what to think.
« Reply #9 on: June 18, 2015, 15:02:39 »
The performance improvement was VERY noticeable when they added OpenCL support in C1. I'm sadly seeing nothing like that in LR.
