Author Topic: Previews  (Read 3693 times)
Previews
« on: June 10, 2015, 18:06:28 »
Ok, did not see a forum for site issue discussion so I try here ;-)
When using preview, the attachments are not shown.
When having posted, I am not returned to the thread but the containing forum.
There also does not seem to be a way to set a "notify me on replies" option by default.
Am I missing a config option?
thx
Chris Wahl
  • Mannheim, Germany
Re: Previews
« Reply #1 on: June 10, 2015, 19:30:27 »
Notification options are under "Profile" --> "Account Settings" --> "Modify Profile" --> "Notifications" --> "Turn notification on when you post or reply to a topic"
Works for me ...
Re: Previews
« Reply #2 on: June 10, 2015, 21:19:56 »
I knew it was a PIFOK ;-)
Found the return to topic option as well, now I only miss the uploaded images in previews.
thx
Re: Previews
« Reply #3 on: June 10, 2015, 22:25:21 »
We're trying to fix how the images look but haven't out how to do it yet, most of us are pretty new at this :)
Two known issues:
- Hyperlinks aren't resized to fit the screen (you need to scroll now)
- Attached images show as small previews instead of a full res image
Re: Previews
« Reply #4 on: June 11, 2015, 07:22:05 »
Need a hand?
Not that I am a web guy ;-)
Me thinks that would require quite a bit of processing on the server side.
And they can not be placed inline...
Re: Previews
« Reply #5 on: June 11, 2015, 09:21:16 »
Does the option "Resize images when showing under post" not work?
I also found this:
http://www.simplemachines.org/community/index.php?topic=505050.0
http://custom.simplemachines.org/mods/index.php?mod=1197
Re: Previews
« Reply #6 on: June 11, 2015, 23:06:38 »
We tried some of fthe mods on a test forum and had severe trouble with them. Later found a css-based fix that apparently works. You do need to link to the image using BBC-tag 'img' (image button). Flickr hosting works great and so might other sites do, but not tested in detail yet.
A crude and cumbersome method, not really a fix, is adding the image as an attachment, get the local URL from that, then enclose this URL in the img tags.
Re: Previews
« Reply #7 on: June 12, 2015, 07:12:43 »
The Team's current thinking is found here http://nikongear.net/revival/index.php/topic,64.0.html
Re: Previews
« Reply #8 on: June 12, 2015, 08:37:35 »
Thanks Bear, I was wondering about the Posting Guidelines.  I do not post images often and try to keep them to under 500KB.   Very happy to have the new site up and running.  If, and when, I get an image worth posting I'm sure I will learn how  :) .
I appreciate the combined efforts of all to launch and massage the Beta.
Tom
