Author Topic: [Theme] Your best unsharp photo  (Read 168002 times)
Re: [Theme] Your best unsharp photo
« Reply #615 on: October 12, 2018, 10:03:10 »
Enjoyable combination, isn't ?
Yes it has a nice rendering, but don’t like harsh light at f1.2. And the Df is a joy with MF Nikkors :)
« Reply #616 on: October 12, 2018, 10:59:07 »
Be gentle when doing post processing of files from the fast lenses such as 50mm 1.2, 55mm 1.2 and Noct-Nikkor
If you use the 'sliders' too much or too aggressive in processing then the result will very quickly be harsh and rough looking,,,
My recommendation is to choose such lenses only if you would like an image with soft rendering, don't try to force sharpness into the image or you will end up with bad bokeh and a strange look of the file,,,
Instead of bumping up clearity, contrast and or sharpness, try with zero compensation or even pulling down these, maybe add colour or vibrance saturation only instead.
And as a final touch add selective sharpening only on the areas where the focal plane is!
« Reply #617 on: October 12, 2018, 11:28:09 »
The one that got away.
Love this cinematique image!
  • Fairbanks, Alaska
« Reply #618 on: October 12, 2018, 13:56:34 »
Sounds like a sports fisher ;)
...Or ptarmigan hunter, although in this case the weapon was the 300 PF.  ;D
Thanks for the comments both Bent and Akira.
JJChan
  • JJ Chan
« Reply #619 on: October 12, 2018, 16:55:13 »
Finally got my first rangefinder camera, trading Sony A7II, D200 and several lenses.
I'm getting about 30% in focus and the rest is a mess. Really hard in low light and not seeing what you expect as with DSLR. Add in lens that rotate the other way to Nikon, is f1.2 and aperture ring also rotating wrong way and the learning curve is very steep...
« Reply #620 on: October 24, 2018, 11:39:40 »
The dedicated astronomical telescopes don't have or need lens "barrels", because they are used at night with no stray light.
Then, I realized that the focal lengths of the ubiquitous closeup lenses are in the range of popular long lenses.  My Kenko Pro1D AC closeup lens No.2 is an achromatic 500mm lens.
So, why not trying to hold the lens around 500mm away from my trusty D750 without my beloved AF-S 50/1.8G to shoot the full moon?
It was so difficult not only to hold the lens and the camera correctly but also to hold my breath during the proceduere.  I tried twenty-some shots and had to stop before I would suffocate.  :o :o :o
Even though this is the "best moon shot" I could get, I thought it deserved being posted here.   :P
« Reply #621 on: October 24, 2018, 11:56:06 »
"it worked" -- what more can one ask for? nice try.
« Reply #622 on: October 24, 2018, 12:42:45 »
Thank you, Birna, for the encouragement!
« Reply #623 on: October 24, 2018, 22:16:24 »
it more than worked, IMHO.
I think this is a great interpretation of the moon !
« Reply #624 on: October 24, 2018, 22:31:29 »
Akira, I would have loved to see you in action!
« Reply #625 on: October 24, 2018, 23:21:42 »
Thank you, Hans!  I myself like the image.
Jakov, I would have looked like an idiot trying to reach for the moon.   :D
Ashlandish
« Reply #626 on: October 25, 2018, 02:56:05 »
Nah, you would have looked like an ambitious photographer reaching for the stars...reaching for an image is surely laudable  :)
Tim Becraft
« Reply #627 on: October 25, 2018, 03:43:31 »
Oh, Tim, you are too kind!   :)
Mauricio Avila
« Reply #628 on: November 02, 2018, 07:56:08 »
Unsharp or soft?
 :D
Saludos,
Mauricio
timh
  • uMhlanga, South Africa
« Reply #629 on: November 17, 2018, 18:58:20 »
It's not too hard to get an unsharp photo with the D90 and the 50mm f/1.8D wide open.
Timothy Hodgkinson
