Author Topic: How to modularily mount a projection lens  (Read 13557 times)
Re: How to modularily mount a projection lens
« Reply #15 on: August 05, 2017, 22:23:22 »
I have some news, based on some pre-production samples I just tested:
I have discussed with Rafcamera to add a filter mount into their M65x1 camera adapter, to accept 40.5mm standard filter mount, so as to allow ND (or other filters) to be mounted inside. As I noticed due to the speed of thoses projection lenses, ISO could not be lowered enough to avoid over-exposure.
Soon available in quantities (so far) for Nikon, Sony-E and mft (micro 4/3)
Wow, I would want such a function for DSLR lens to m4/3 body adapters, too!
« Reply #16 on: August 06, 2017, 02:33:50 »
This could be done by modifying such adapter, the M42 or Nikon one is relatively long and could be done,
using a technique which Nikon and others (Leitz, Kilfitt, Astro,...) have already developed
(c) Kenrockwell.com
Here was an announcement about such a solution:
http://www.43rumors.com/new-deo-tech-drop-in-filter-adapter-coming-soon/
and here is the product for sale:
https://www.bhphotovideo.com/c/product/1190855-REG/deo_tech_deoowlng2fe1_owl_nikon_g_lens.html
(c) Deo Tech
Here is their product video: https://www.youtube.com/watch?v=XL4JuXaCsc4
« Reply #17 on: September 01, 2017, 11:31:21 »
Interesting product! Thanks for sharing links ;)
« Reply #18 on: September 01, 2017, 14:42:32 »
I bought it and it is on my way to me, will report about it, once I had the chance to test ;-)
« Reply #19 on: September 01, 2017, 17:23:51 »
Klaus, thank you very much for the link!  I ordered Nikon G to MFT adapter that was exactly what I wanted!
Upon its arrival, I will assess its quality to see if it is worth buying a special filter for my purpose.  :)
« Reply #20 on: September 02, 2017, 20:58:37 »
Excellent, do let us know Akira!!
« Reply #21 on: September 03, 2017, 03:28:46 »
Most definitely!  Apparently it can take about a month to be in stock, shipped and delivered, so I'm looking forward to your initial review!
« Reply #22 on: September 11, 2017, 21:28:46 »
On my return from Sweden, the filter slide in adapter has arrived. Looks very well made, will test it tomorrow, weather permitting
« Reply #23 on: September 11, 2017, 23:50:10 »
Great!  Please check out the infinity focus with the "usual" Nikkor lens as well.
« Reply #24 on: September 28, 2017, 22:41:04 »
(c) Kenrockwell.com
(c) Deo Tech
Unpacked it, did some quick indoor mechanical test. Looks well made, nothing blocking, all working. Filter slider
sits a bit lose, hold by two ball bearings, but won't fall off.
« Reply #25 on: September 29, 2017, 00:55:24 »
Sounds promising.  Did you buy the Nikon F to m4/3 adapter?  I haven't yet received any info on the stock or the shipment from B&H.
JCDowdy
« Reply #26 on: September 29, 2017, 01:21:22 »
I have been following the development of the Owl filter adapter for some time.
I have refrained from ordering one pending some independent reviews so I am eager to hear how it performs!
John C. Dowdy, Ph.D.
« Reply #27 on: September 29, 2017, 18:57:20 »
Yes, the Nikon version I have (for my UV-Nikkor 105mm)
« Reply #28 on: September 29, 2017, 18:59:29 »
The problem is to have 52mm filters with low frame height, the only downside it has (so far). If it is really light tight, I have to test (and I do have some doubts, as many normal adapters, even the most expensive ones, do leak...). Unfortunately not that much time currently availbale for such.
Step adapters cannot be mounted, it has to be a low height 52mm filter frame! (So a Baader-U filter for instance needs to be remounted)
« Reply #29 on: September 29, 2017, 19:43:48 »
Thanks, Klaus, for the details of the adapter.  Hope the filter I intend to use is of a thin-frame type.
