Author Topic: Nikongear Website Disclaimer  (Read 14561 times)
Andrea B.
  • Technical Adviser
« on: August 12, 2015, 18:24:43 »
Website Disclaimer
1.       Introduction
1.1     This disclaimer shall govern your use of Nikongear (.net, .com, .org), herein after known as 'our website'.
1.2     By using our website, you accept this disclaimer in full; accordingly, if you disagree with this disclaimer or any part of this disclaimer, you must not use our website.
1.3     Our website uses cookies only to monitor session length; by using our website or agreeing to this disclaimer, you consent to our use of cookies in accordance with the stated use.
2.       Credit
2.1     This document was created using a template from SEQ Legal (http://www.seqlegal.com).
3.       Copyright notice
3.1     Copyright (c) [year(s) of first publication] [full name].
3.2     Subject to the express provisions of this disclaimer:
         (a)     we, together with our licensors, own and control all the copyright and other intellectual property rights in our website and the material on our website; and
         (b)     all the copyright and other intellectual property rights in our website and the material on our website are reserved.
4.       Licence to Use Website
4.1     You may:
          (a)     view pages from our website in a web browser;
          (b)     download pages from our website for caching in a web browser.
4.2     Except as expressly permitted by Section 4.1 or the other provisions of this disclaimer, you must not download any material from our website or save any such material to your computer.
4.3     You may only use our website for your own personal purposes, and you must not use our website for any other purposes.
4.4     Unless you own or control the relevant rights in the material, you must not:
         (a)     republish material from our website (including republication on another website);
         (b)     sell, rent or sub-license material from our website;
         (c)     show any material from our website in public;
         (d)     exploit material from our website for a commercial purpose; or
         (e)     redistribute material from our website.
4.5     We reserve the right to restrict access to areas of our website, or indeed our whole website, at our discretion; you must not circumvent or bypass, or attempt to circumvent or bypass, any access restriction measures on our website.
5.       Acceptable Use
5.1     You must not:
         (a)     use our website in any way or take any action that causes, or may cause, damage to the website or impairment of the performance, availability or accessibility of the website;
         (b)     use our website in any way that is unlawful, illegal, fraudulent or harmful, or in connection with any unlawful, illegal, fraudulent or harmful purpose or activity;
         (c)     use our website to copy, store, host, transmit, send, use, publish or distribute any material which consists of (or is linked to) any spyware, computer virus, Trojan horse, worm, keystroke logger, rootkit or other malicious computer software;
         (d)     conduct any systematic or automated data collection activities (including without limitation scraping, data mining, data extraction and data harvesting) on or in relation to our website without our express written consent;
         (e)     [access or otherwise interact with our website using any robot, spider or other automated means;]
         (f)      [violate the directives set out in the robots.txt file for our website; or]
         (g)     use data collected from our website for any direct marketing activity (including without limitation email marketing, SMS marketing, telemarketing and direct mailing).
5.2     You must not use data collected from our website to contact individuals, companies or other persons or entities.
5.3     You must ensure that all the information you supply to us through our website, or in relation to our website, is accurate and non-misleading.
6.       Limited Warranties
6.1     We do not warrant or represent:
          (a)     the completeness or accuracy of the information published on our website;
          (b)     that the material on the website is up to date; or
          (c)     that the website or any service on the website will remain available.
6.2     We reserve the right to discontinue or alter any or all of our website services, and to stop publishing our website, at any time in our sole discretion without notice or explanation; and save to the extent expressly provided otherwise in this disclaimer, you will not be entitled to any compensation or other payment upon the discontinuance or alteration of any website services, or if we stop publishing the website.
6.3     To the maximum extent permitted by applicable law and subject to Section 7.1, we exclude all representations and warranties relating to the subject matter of this disclaimer, our website and the use of our website.
7.       Limitations and Exclusions of Liability
7.1     Nothing in this disclaimer will:
         (a)     limit or exclude any liability for death or personal injury resulting from negligence;
         (b)     limit or exclude any liability for fraud or fraudulent misrepresentation;
         (c)     limit any liabilities in any way that is not permitted under applicable law; or
         (d)     exclude any liabilities that ma y not be excluded under applicable law.
7.2     The limitations and exclusions of liability set out in this Section 7 and elsewhere in this disclaimer:
         (a)     are subject to Section 7.1; and
         (b)     govern all liabilities arising under the disclaimer or relating to the subject matter of the disclaimer, including liabilities arising in contract, in tort (including negligence) and for breach of statutory duty, except to the extent expressly provided otherwise in the disclaimer.
7.3     To the extent that our website and the information and services on our website are provided free of charge or for a nominal, voluntary subscription fee, we will not be liable for any loss or damage of any nature.
7.4     We will not be liable to you in respect of any losses arising out of any event or events beyond our reasonable control.
7.5     We will not be liable to you in respect of any monetary losses, including (without limitation) loss of or damage to profits, income, revenue, use, production, anticipated savings, business, contracts, commercial opportunities, goodwill or sales transactions between members.
7.6     We will not be liable to you in respect of any loss or corruption of any data, database or software.
7.7     We will not be liable to you in respect of any special, indirect or consequential loss or damage.
7.8     You accept that we have an interest in limiting the personal liability of our owners and, having regard to that interest, you acknowledge that we are a limited liability entity; you agree that you will not bring any claim personally against our owners in respect of any losses you suffer in connection with the website or this disclaimer (this will not, of course, limit or exclude the liability of the limited liability entity itself for the acts and omissions of our owners).
8.       Variation
8.1     We may revise this disclaimer from time to time.
8.2     The revised disclaimer shall apply to the use of our website from the time of publication of the revised disclaimer on the website.
9.       Severability
9.1     If a provision of this disclaimer is determined by any court or other competent authority to be unlawful and/or unenforceable, the other provisions will continue in effect.
9.2     If any unlawful and/or unenforceable provision of this disclaimer would be lawful or enforceable if part of it were deleted, that part will be deemed to be deleted, and the rest of the provision will continue in effect.
10.      Law and Jurisdiction
10.1   This disclaimer shall be governed by and construed in accordance with [English law].
10.2   Any disputes relating to this disclaimer shall be subject to the [exclusive / non-exclusive] jurisdiction of the courts of [England].
11.    Statutory and Regulatory Disclosures
11.1  We are not currently registered. We are registered in [trade register]; you can find the online version of the register at [URL], and our registration number is [number].
11.2   We are subject to [authorisation scheme], which is supervised by [supervisory authority].
11.3   We are registered as [title] with [professional body] in [the United Kingdom] and are subject to [rules], which can be found at [URL].
11.4   We subscribe to [code(s) of conduct], which can be consulted electronically at [URL(s)].
11.5   Our VAT number is [number].
12.     Our Details
12.1   This website, Nikongear (.net, .com, .org), is owned and operated by Bjørn Rørslett (Norway), Erik Lund (Denmark), Jakov Minic (Netherlands) and Jan Anne Offereins (Netherlands).
12.2   We are registered in [England and Wales] under registration number [number], and our registered office is at [address].
12.3   Our principal place of business is at [address].
12.4   You can contact us by email to nn@naturfotograf.com.
